Hey guys I have a rebuilt iron Duke with about 4k Miles. I am starting to hear a little bit of rocker or valve ticking. I know these engines are known for sounding very mechanical, but how much is normal?
Go to the nearest truck stop and park it next to an idling Peterbilt. If you can hear the Fiero, you should worry.
Haha That makes me feel much better, Id hear the exhaust but not the motor. The Cat was removed by the last owner (straight Piped) now a cherry bomb into the OEM muffler.
We have no way of knowing from your post what valvetrain noise you're currently experiencing. In what manner are we to tell you "how much is normal"? Perhaps it's loose connecting rods you're actually hearing. Stick your phone in the engine bay and record/post a video so we can at least listen to the engine.
Does the sound go away if you pour a little oil in while it is idling?
Nope it sounds the same. I suspected oil not getting to the rockers, so i puled the cover. Everything is soaked in oil. So much so the bolt heads on the rockers are below The oil line.
It's difficult to tell if there's a problem. Might've helped a bit if you could've revved it up and down a few times to hear how/if the clatter changes.
Were all pushrods checked for straightness prior to re-installation?
Were all rocker bolts snugged up to the torque specs?
I torqued the bolts down to 22 lbs and yep, all pushrods went through the flat table roll test. Ill get more video tonight. My phone was dying it actually died recording. Haha thats why there were vertical lines in the video.
You must torque down the rocker arm bolts while the lifter is on the base circle of the cam. If you just torqued them down without insuring that , they will be out of adjustment.
[This message has been edited by Dennis LaGrua (edited 11-15-2018).]
So, I listened to the video, and in my opinion, it sounds like a super-smooth Iron Duke! haha. I've had a few of these L4s, and I'll put it this way, they absolutely sound like little truck engines. They are anything but smooth.
I think I read somewhere in here that you said it has hydraulic lifters? Is this an 85? Normally the 84s came with the flat-tappet, and some 85s (mid-way through the year) got the roller lifters, which are WAY nicer... though, still a noisy engine.
As I think you said... they require no lash adjustment.
I wouldn't be too concerned. Aside from the recall connecting rod issue that's been fixed in them already, the biggest problem for these engines was cyl head cracking when they're allowed to overheat. But there are still some things you can do to these cars for relatively cheap that can improve the performance a little and make the car feel a bit smoother. I just checked, couldn't find anything quick to post here... but there are a few options you can look at. Crane has some... but they'll definitely "smooth out" that sound. But don't be too concerned about it. You would know if there's something wrong.
Duke "valve noise" can be a few things... 2 big items: Hydro lifters have a "sweet spot" to work completely quietly. If compressed too low can made noise and wreck the push rods or worse. Too high makes noise even break them because small spring clips on them won't last long. Too high and rockers etc can make noise too. Cam gears can make noise too. More so when using metal cam gear.
Is/was shims to set valve lash on non adjust Duke and some others but have to be careful how their installed for same reason above.
Note that if you shaved/decked the head and/or block then often the lifters are too compressed and will have problems now or soon. Depends exact total of machining for either/both. Is why Felpro HeadSaver® and others make/made "shims" to go w/ head gasket to make up dimensions in that space.
Thank you very much! Yeah its an 84 with flats. I was concerned that it was an issue, and after hearing all your experience, and watching videos of other dukes, i think its gonna be fine. Ive seen some videos that sound like a diesel running haha.
THIS was an annoying rattle:
Turned out to be a torque converter bolt that came loose and started flying around.... yup.... took me forever to figure it out. I guessed everything from the catalytic converter, to something on the exhaust vibrating... everything I could think of.
