  THIRD MOUNTING SCREW ON AIR VENTS?
THIRD MOUNTING SCREW ON AIR VENTS? by QCMANAGER
Started on: 05-16-2015 11:28 PM
Replies: 4 (194 views)
Last post by: 2.5 on 05-18-2015 08:55 AM
QCMANAGER
Report this Post05-16-2015 11:28 PM Click Here to See the Profile for QCMANAGERSend a Private Message to QCMANAGEREdit/Delete MessageReply w/QuoteDirect Link to This Post
A couple of the directional vanes are broken off of my air vents that are mounted at each end of the dash. I was able to obtain some nice used ones but when I tried to remove the broken ones and install the new ones I discovered another one of those lovely design flaws that the engineers at Pontiac threw in just as a practical joke. There is a third screw holding these vents to the dash that is inaccessible. It seems to be behind the windshield pillar molding.
Can anyone please advise the EASIEST way to access this screw so that I can change out these vents? It just seems ridiculous to me to place a mounting screw where you can't even see it.
Thanks for the help.
Total ratings: 154
Report this Post05-17-2015 12:09 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can remove the A pillar trim, but be careful not to break the tabs that hold it in place. If you aren't experienced with that, I suggest that you find a practice dummy in a junk yard to see how they are installed. Due to age, they are often pretty brittle.
The other way is to remove the instrument pod, the center radio/hvac pod, remove the screws from underneath each end of the dash that holds it in place, and the 2 screws in the front ledge of each radio speaker. Then you can slide it back the inch or so to give you access to those two screws.
QCMANAGER
Report this Post05-17-2015 12:24 AM Click Here to See the Profile for QCMANAGERSend a Private Message to QCMANAGEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the information, can you elaborate on how to remove the a-pillar trim?
Pull up, down, in, out, etc?
Total ratings: 466
Report this Post05-17-2015 12:33 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought this topic sounded familiar.
REMOVE AND REPLACE AIR VENTS
Please try to refrain from posting multiple threads about the same issue.
Report this Post05-18-2015 08:55 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Somewhat helpful threads on it.
https://www.fiero.nl/forum/A...090219-2-082223.html
https://www.fiero.nl/forum/A...010219-2-005077.html
Its fairly easy to break tabs off.
