Yep it's not too bad of a job. I've found it's an easier job removing the A piller panel to unbolt the upper seat belt attachment, it takes a 40 or 45 torx I think. Next, take the long screw out of the front edge of the back corner trim piece and now you pull that panel inward to uncover the last 1/2" of the A piller trim that is tucked under it. You probably could get away without unbolting and unsnaping this panel, but It makes it easier to remove the A piller panel later on.
Now to remove, pull firmly but carefully along the A piller to pull out two plastic trees. Pull the trim outward and down along the top edge of the window opening to pull out the two plastic tabs out from their clips (be real careful it's easy to break those tabs right off). It seems like you can pull and pull on it and it won't budge, but if you pull it just right it comes off easy. Replace the plastic trees to the new panel and reverse the steps. Hope this helps...
I don't think I want to ask you how you broke it, but it almost sounds like that commercial "People do strange things to their cars," Could it be more like "People do strange things in their Fieros?" Be more careful next time
hehe
Brent
HugGRRRFiero@hotmail.com
