Hey everybody! I've been planning this for a long time but just now getting started. I really don't have a clue what I am doing. However, I believe that with some dedication and the help of this great thing known as the internet, I will complete it. I'm well aware that I am not knowledgeable or experienced at any of this. Normally I would be embarrassed to ask stupid questions or let people see the stupid mistakes I've made. However, I've decided to forego any pride I may have in order to fully use you guys to my advantage.
Any words of advice, questions, etc. is not only welcome but expected.
Here's my gold 87 GT in all it's glory.
It's nothing pretty and I don't really care at the moment.
I picked up an 88 cradle from RUNDLC down in Sacramento.
Then I bought a 70k mile L36 from a 2000 or 2001 Impala.
When I started looking it over, I noticed I had a strange front exhaust manifold and an A.I.R. system.
Then I did the first thing I regret, I pulled the heads off for no good reason.
Since they are off, I'm going to at least get the ports and casting marks cleaned up a little bit. I'm taking them into a reputable head shop in the morning. When they get back I will put the new valve springs, seals, retainers, keepers, etc. together and paint the heads. I dropped off my oil pump cover and crank sprocket with Fieroking to get worked over for the double roller timing chain. When that gets back I will put in my ST1 cam.
Tonight I cleaned up the decks on the block really well and made my second stupid mistake. I didn't cover up the cylinders, oil galleys, water jackets, or anything while I was scraping the old head gasket off and I'm sure I got the composite residue stuff in everything.
So my first stupid question: How can I make sure that the head gasket residue that I got everywhere won't hurt anything? I don't think I got anything in the lifter valley. I think I can blow everything out of the cylinders and hopefully not have to worry about getting anything to the rings. I will also chase the threads for the head bolts. But what about the oil galleys and water jackets?
Hey nice choice on the motor, since it's on a stand you should be able to clean things out. When I bought my Northstar back from a friend there was a bunch of crap in it from grinding without the valve covers on. Once it was apart I tipped it upside down and emptied a few cans of brake cleaner on the heads and it came clean. You have a little less than a year to get it finished for the Fest so get to it
Do you think I could pump oil through the oil galleys some how? I plan on having it done and running over the winter so I should definitely have it at the fest next year.
Doesn't it feed the heads through the pushrods? That is how they did it in the dark ages right
You should be ok, if you want to flush the cooling system I would wait till it's back together and flush the motor with a hose.
Just use assembly lube, and pack the oil pump with vasoline.
Leave the spark plugs out, and jump the starter terminal to spin it. You would be amazed at how much oil the pump moves on the 3800. Do you have the timing cover off yet? see the SIZE of the oil pump?
I used a sharpening stone like this with some oil and the block cleaned up really nice. Had the heads fly cut to a very fine finish and used felpro composite gaskets, copper spray and arp head studs. I'm making quite a bit of power right now with good results (knock on wood). I have some Cometic MLS gaskets on standby but I don't think i'll ever need them.
I love how these swap threads just keep on coming and coming, another to add to my list.
I wouldn't worry about pulling the heads for no reason, I think it's actually a good idea if not on a tight budget, because these engines chip pistons so it's a hell of a lot easier to inspect it with the heads off, gives you a better idea of what you have.. It also gives you the opportunity to refresh the heads, maybe get new guides pressed if needed, freshen the valves and have it all machined, maybe even ported.... It's not really a big deal.
------------------ 86 Fiero GT 4spd - L67 swap: VS cam, GenV. Needs exhaust (ETA 9/13) Build Progress 98 GTP - Some mods
Thanks, I needed some reassurance
I just dropped the heads off at a very highly reviewed head shop. Getting a mild porting, valve job, new bronze guides, etc.
I've got the ARP studs and will also be using the felpro gaskets with copper spray. How much do you torque the studs down into the block? I'm not going to run quite as much boost as you so hopefully mine will hold up as well as yours.
I envy you so much right now . This type of build along with an Ecotec 2.2+M62/ F23 swap has been on my wish list for years now.
Bah, I really need to get my business going soon- too much eye candy on the forums . Good luck with this man, I hope you can get it up and running asap with the least amount of problems!
Thanks! It's gonna need a lot of help from the forum though as all I've ever done was a half-assed rebuild of an old SBC 350 and put it in an S10 and I had help! I just recently moved and don't have the friends and family to ask for help like I used to.
But like I said, if I'm patient and don't do anything that I'm not sure of without reassurance from the pro's here, I should be fine
The engine stuff will be the easy part as long as you keep the stock bottom end. No sense in reinventing the wheel as its a waste to even think about swapping in different rods and pistons. Good luck. Looking forward to watching your build. I'll be doing the same swap myself. Just need to find me a donor GP.
[This message has been edited by Slow6 (edited 08-21-2013).]
i went 80ft lbs last time I did it.. Works fine. I think spec for alum head guys out there is around 65 or 70 as thats what I did my honda to.
Sweet talking aside.. only bad things come from removing heads from a motor... porting doesnt really help anyone... I proved it to be a fairly decent waste without some seriously crazy goals.
Yeah I still kind of regret pulling the heads but live and learn. They're mainly just cleaning the bowls and the casting ridges a little bit.
The guy that ported them has done many 3800 heads. I don't have any flow numbers, but I believe he does very good work.
Flycut the decks, new bronze valve guides, 3 angle valve job, etc.
My one concern is that I may not have enough valve height above the modified retainers. It's definitely less than before. How much do I need before the rocker will interfere with the retainer?
Is there anybody with the modified titanium retainers and reusable rocker bolts that is willing to pull a valve cover and a rocker to get a straight edge and a feeler guage in there? I'm probably going to put on the rockers tonight but I won't be able to tell what's it's like when the valves are open.
Your head guy should asked how much lobe lift your cam had to determine valve lift to make sure there was no coil bind on the springs the spring height was right and that there was enough seal to retainer clearance... An st1 cam has .512 valve lift, i know guys running an s1x cam from intense with .514/.526 valve lift on modded retainers and viton valve stem seals with no clearance issues
[This message has been edited by black88fiero (edited 09-06-2013).]
Maybe I didn't word that very good. I have .600 lift available. The head guy knew what lift my cam was. I'm worried that I don't have enough valve stem sticking out above the retainer.
Edit to add: The spring height is dead on per PAC and plenty or clearance between seal and retainer.
[This message has been edited by NoMoreRicers (edited 09-07-2013).]
your gonna just have to bolt up your heads and turn it over and check your geometry and clearances..
Unfortunately, I think you're right. I was hoping to have some assurance beforehand. Oh well. The owner of the head shop wants to talk to Zoomer at ZZP about it, so I emailed Zoomer earlier this evening.
I have modded retainers but i used stock keepers and have no issue. Id think youll be ok as long as the keeper notch was in the same location as stock. That way the retainer location didnt move
