Update System
  3800 Secondary Air Injection Valve
by NoMoreRicers
Started on: 08-03-2013 02:11 AM
Replies: 8 (732 views)
Last post by: NoMoreRicers on 08-08-2013 03:24 PM
NoMoreRicers
Report this Post Click Here to See the Profile for NoMoreRicersClick Here to Email NoMoreRicersSend a Private Message to NoMoreRicersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can somebody tell me about this valve? The part number is 24508523.
I pulled it off because it crushed my valve cover.
I'm just curious.
jb1
Report this Post Click Here to See the Profile for jb1Click Here to Email jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine did not have it that I am aware of, looks like a good part to delete...
87 GT
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
NoMoreRicers
Yeah, it looks like it might have only been on California cars.
I guess I'll just block it off and worry about the code for it later.
NoMoreRicers
jb1
you going to have to have the VATS turned off so they can just eliminate code for that as well...
87 GT
86GT 3800 n/a
My Build
NoMoreRicers
I'm guessing nobody else's rear exhaust manifold looks like this:
FlyFieroGT
Report this Post Click Here to See the Profile for FlyFieroGTSend a Private Message to FlyFieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
A.I.R. - second air induction reaction is a after combustion emission systems first used in Calif in1966.
SAir reduced emissions approx 90 percent
Air is supplied by Saginaw design belt or elect driven pump. In 1980 a pulse SAIR system using tubing and check valves added to the exhaust manifold used the negative pressure pulse to draw air into the manifold.
A.I.R system dosen't effect engine performance . You can remove it if you can pass your local emission police.
Lou6t4gto
Report this Post Click Here to See the Profile for Lou6t4gtoClick Here to Email Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope, Mine hasn't Got that upper tube.
NoMoreRicers
Yeah, I haven't noticed it on any of the other 3800's I've seen.
