  Auto trans selector indicator
Auto trans selector indicator by fierofrenzy
Started on: 06-23-2018 07:19 AM
Replies: 8 (303 views)
Last post by: kendell on 07-05-2018 01:11 AM
fierofrenzy
Report this Post06-23-2018 07:19 AM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, the auto trans selector indicator "thing".....or whatever its called. You know, that orange bar that moves up and down in your shift indicator telling you what gear your in. Mine is way out of wack. Sounds like it should be a simple fix, but I don't want to start breaking any kind of clips while pulling the console apart. Anybody got some tips on this one ?
Report this Post06-23-2018 11:43 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pointer just slips on the shifter when install the console. No adjustment needed or possible. If doesn't move then console is installed wrong.
Paint on it or pointer can fade to white from sun light (UV). Can't fix it w/o breaking plastic light fixture.
Shift "knob" is attach to shifter w/ a clip you pull/push from front. Used wheel block so can shift to D etc to see it. then pull 4 screws under ash trays.
tshark
Report this Post06-23-2018 12:16 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you a member of the club down there? They have detailed info on this.
pcgold
Report this Post06-24-2018 11:27 AM Click Here to See the Profile for pcgoldSend a Private Message to pcgoldEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had to fix mine. Simple. Take off the boot and plate, reposition the indicator and away you go.
johnyrottin
Total ratings: 85
Report this Post07-01-2018 09:42 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is an old thread to show you how to freshen those up,
https://www.fiero.nl/forum/A...130314-1-084600.html
johnyrottin
Total ratings: 85
Report this Post07-01-2018 09:48 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
johnyrottin
Member since Oct 2007
delete - duplicate
[This message has been edited by johnyrottin (edited 07-02-2018).]
tshark
Report this Post07-01-2018 11:08 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good to see you're still here, Johnny!
fierofrenzy
Report this Post07-02-2018 06:28 AM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You guys did it again ! Thanks so much. I bet this is the best auto forum on the internet.
kendell
Report this Post07-05-2018 01:11 AM Click Here to See the Profile for kendellSend a Private Message to kendellEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pretty tips on that thread.
