  headslights wont pop
headslights wont pop by fierofrenzy
Started on: 08-20-2017 07:40 AM
Replies: 16 (326 views)
Last post by: 2.5 on 08-22-2017 10:11 AM
fierofrenzy
Report this Post08-20-2017 07:40 AM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK rocket scientist, heres the problem....(this time ) My headlights won't pop up. That's it ! When I flip the switch the lights go on ( as I can see by opening up the front hood) but the units stay down. My fuses are good. Can anyone help me to see the light ? Once again, I appreciate all the responses.
E.Furgal
Total ratings: 278
Report this Post08-20-2017 08:06 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
push on the light switch.. like you are turning them on, but keep pushing see if that does it..
My indy I have to hold it (push) to raise the lights,
fierofrenzy
Report this Post08-20-2017 02:31 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
No good.....I tried holding down on the switch but they still did not work. I guess the switch is bad then. Is this the problem ?
Rsvl-Rider
Report this Post08-20-2017 02:44 PM Click Here to See the Profile for Rsvl-RiderSend a Private Message to Rsvl-RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not necessarily...Do the headlight motors run but the lights don't come up? If so then most likely the motors need to be rebuilt to replace the plastic pegs inside that turn to powder over the years. Lots of threads and how-to's on here and on you-tube. Parts are readily available. There are two different types of motors depending on the year of your car so look for the right instructions.
Is this car new to you? If the problem affected both sides at the same time then probably something other than motors... Relays, headlight control module (87-88 only) etc.
Fiero Thomas
Total ratings: 125
Report this Post08-20-2017 03:40 PM Click Here to See the Profile for Fiero ThomasSend a Private Message to Fiero ThomasEdit/Delete MessageReply w/QuoteDirect Link to This Post
What series lights do you have 84-86 or 87-88. That will help. If 84-64 then your isolation relay could have killed itself
1987 Fiero GT T-Top
2012 Kia Forte Koup
2017 Kia Forte S
FieroNews
FieroNews Spare Tire Cover
FieroNews Windshield Banners
fierofrenzy
Report this Post08-20-2017 05:41 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
the car is an 88 formula. its not the plastic inserts in the motors because they have been replaced. the motor(s)are not running when I hit the switch. I bet its the relay. Heres why. When I replaced my water pump a few weeks back I was trying to get a certain wire harness out of the way. It went to a black box right behind the battery. I was tugging on the wire harness after removing the fastener bolt but it would not separate so I just worked around it. So,once I started the car to test the pump ( which worked fine) , that's when the headlights would no longer pop up. so.......once again....now what ?
liv4God
Report this Post08-20-2017 06:29 PM Click Here to See the Profile for liv4GodSend a Private Message to liv4GodEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since its an 88 car, it is most likely the control module has gone bad. You can find it on the front side wall inside of the drivers side fender. It's a black box about 3"x3" with wires coming out of it.
I had mind go out and both headlights stopped at the same time. I found one from someone on here for $50-60, but it took some searching. In the meantime I just left them up manually.
[This message has been edited by liv4God (edited 08-20-2017).]
fierofrenzy
Report this Post08-20-2017 07:57 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK...i'll check it out then figure out my next move. I have a supplier buddie out in Texas who's good for parts, and an excellent repair shop if I'm totally stumped. One way or , she'll get fixed. Till then, I guess I just need to get home before dark..... : )
Report this Post08-20-2017 08:13 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You should be able to turn the little knobs on the motors and crank the lights up manually.
Report this Post08-20-2017 08:20 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe, not likely.
Try losing both 1 turn of knob then try. Works now motors are problem.
Very common problem for 1 motor both both can bind up. More so when DIY tried to "rebuild"/fix them.
See my Cave, Gen 2 HL Motor
But if motors are dying then just get new Cardone ones or can be fooling w/ them again and likely soon.
Report this Post08-20-2017 08:22 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or have someone walk in front of the car carrying a lantern.
fierofrenzy
Report this Post08-20-2017 08:44 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
hahaha....I never thought of that. I know about the manual crank up. I actually use it from time to time. but that's totally uncool. everything on my/our Fiero's should work. we need to uphold the image.
Report this Post08-21-2017 12:36 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
No we don't!
Buck531
Report this Post08-21-2017 07:53 AM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had to flip my headlight switch any where between 4-6 times before the headlights popped up. Got a cheap replacement switch from rock auto for around $11 last week and they go up every time now.
03 Buick Regal. 13.0x @103
87 Fiero GT. L67, XP, Ported heads, SD headers, 3.2. 12.6@108 1.8 60'.
Report this Post08-21-2017 09:16 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
The motors are plugged in, right?
fierofrenzy
Report this Post08-21-2017 08:55 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
uhhh.......yea......
Report this Post08-22-2017 10:11 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Its always worth checking the obvious first.
