  Radio power
Radio power by LornesGT
Started on: 11-02-2014 02:26 PM
Replies: 5 (213 views)
Last post by: LornesGT on 11-03-2014 07:22 PM
LornesGT
Report this Post11-02-2014 02:26 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought the 1999 radio at the junk yard and I am wanting to see if it will power up before I buy the adaptor and install it.
I assume the dimmer wire must be powered as well to see the display. Is 12 volts to much to burn out the lights?
So I should power The battery wire, memory wire, dimmer wire? Any other wire?
Spoon
Total ratings: 61
Report this Post11-02-2014 04:41 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a quick response, you'll have to provide a ground.
Spoon
LornesGT
Report this Post11-02-2014 06:47 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I firgured out the bulb behind the display is burnt or not powered. I place a flashlight behind it and the display works. The bulb is in a tight space and the hex head screws are crazy small.
Fiero Tom
Report this Post11-03-2014 03:41 PM Click Here to See the Profile for Fiero TomSend a Private Message to Fiero TomEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's the answer ........ https://www.fiero.nl/forum/Forum1/HTML/089227.html ... bulbs are available from Rockauto, sometimes the contacts only need cleaning
[This message has been edited by Fiero Tom (edited 11-03-2014).]
Total ratings: 463
Report this Post11-03-2014 05:22 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought the same style radio from the wreckers a couple of months ago. I was disappointed when I powered it up that the display was dead, even though the radio worked fine. I was relieved to discover online that the repair is relatively easy.
Originally posted by Fiero Tom:
Here's the answer ........ Monsoon radio lcd stop working? Here is how to fix it! ... bulbs are available from Rockauto, sometimes the contacts only need cleaning
That's a helpful link. After looking over that thread I posted a question about the bulb which is relevant to this discussion.
[This message has been edited by Patrick (edited 11-03-2014).]
LornesGT
Report this Post11-03-2014 07:22 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I should have waited for a couple of more replies or search for monsoon since I new that was the same design. I spent 15 for the bulb and fixture here. I guess my total for the radio is 26 plus adaptor so still not to bad and it all works.
http://www.ebay.com/itm/301...352214062%26_rdc%3D1
[This message has been edited by LornesGT (edited 11-03-2014).]
