  What windshield wiper blades are you using? (and other wiper info)
What windshield wiper blades are you using? (and other wiper info) by Boostdreamer
Started on: 02-13-2014 06:05 PM
Replies: 11 (870 views)
Last post by: theogre on 02-15-2014 01:18 PM
Boostdreamer
Total ratings: 98
Report this Post02-13-2014 06:05 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is probably one of those subjects that continues to evolve with time and technology. But for now, what kind of wiper blades are you using? I checked out Amazon.com and sorted by best reviews. I saw that the Anco Contour blades were rated pretty high.
http://www.amazon.com/ANCO-...ero+windshield+wiper
Anybody used these? Got some that you recommend? Is it worth it to buy wiper blades on the internet or are the premium blades in local parts stores just as good?
Got any good tips or links about wipers? Here's mine:
Tony Kania started a good thread about changing the wiper arms. "19's and 22's. No silly, windshield wipers. "
https://www.fiero.nl/forum/Forum1/HTML/088069.html
And RWDPLZ had one also: "Found Replacement Wiper Arms!"
https://www.fiero.nl/forum/Forum2/HTML/101621.html
I had one on the sprayers and fluid. "Winshield washer sprayers?"
https://www.fiero.nl/forum/Forum2/HTML/131706.html
And there are a bunch of threads about the "phantom wipe" problem where the wipers come on when you start your car or turn on the blinkers. I fixed mine very easily by swapping in an 88 circuit board. One bolt and one electrical connector is all you have to deal with. Plus, it is just inside the hood on the driver's side and you don't have to get under the car or hang upside down by your knees to get to it!
So, what else should we know about wipers?
[This message has been edited by Boostdreamer (edited 02-14-2014).]
jsmorter
Report this Post02-13-2014 06:10 PM Click Here to See the Profile for jsmorterSend a Private Message to jsmorterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have tried all the anco blades on my fieros over the years. The contours don't seem flexible enough and leave areas where they don't get. The winter blades and the regular ancos seem to work better
87GT2M6
Report this Post02-13-2014 06:41 PM Click Here to See the Profile for 87GT2M6Send a Private Message to 87GT2M6Edit/Delete MessageReply w/QuoteDirect Link to This Post
These are good. Silblades
Boostdreamer
Total ratings: 98
Report this Post02-13-2014 07:04 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
What wiper arms need is a little ramp where they park. When they cycle off and come to a stop at the bottom of the swipe, they ride up a slight ramp and take the pressure off the blades. I think they get bent one way as they swipe downward across the windshield and then are stuck in that position until they are turned on again. If that sit-and-bend situation was eliminated, they would be able to flip back and forth from side to side as the wipers changed direction.
rogergarrison
Total ratings: 551
Report this Post02-13-2014 07:23 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like the Michelin ones. Just for info, you can put a much larger one on the passenger side of a Fiero than the stock one. I think it can take a 22 or 24 inch one. I found that out by chance buying wipers for my Ferrari kit. It will not work on the drivers side. It does a better job cleaning the middle of the glass.
Report this Post02-14-2014 08:39 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The original OEM wiper blades on Fiero's used a very low profile wiper frame. In most cases (where possible) I reuse the frames and install new rubber wipers. Standard wipers use a frame that's too bulky and it looks terrible on a car where the wipers are always exposed.
Blacktree
Total ratings: 350
Report this Post02-14-2014 12:18 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use a single (Anco, I think?) 24" wiper blade on the driver side. The passenger side wiper and mechanism has been deleted. The 24" wiper blade just barely fits. It's literally on the brink of hitting the windshield weatherstripping.
rogergarrison
Total ratings: 551
Report this Post02-14-2014 05:16 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think I made a mistake above. I think maybe the longer one fits the DRIVERS side, NOT the passenger side. Hey, its been 10-12 years since I had one
JohnWPB
Total ratings: 144
Report this Post02-14-2014 06:41 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Following the advice in the above linked thread, I ordered new wiper arms that are easier to change the blades, and no worrys about the little plastic clip breaking. I purchased them at Rock Auto.
Here are the current part numbers and pricing for replacement wiper arms:
mrfiero
Total ratings: 150
Report this Post02-14-2014 06:57 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree with you. I have stock frames and just buy the el cheapo refills at the parts store.
Kevin87FieroGT
Report this Post02-14-2014 09:18 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trico's Exact Fit look and perform OEM. Three years seasonal use and they still work great. Thin rail stock 1980's look. Around here you typically have to ask for them as they are back room stock at most parts stores. At $6-$7 they can't compete with the big names up front. Not sure if they are offered in the 19-22" lengths, but worth asking for.
As for washer fluid, I've never had a problem with any of the blue mixes or the premium brands. Typically just look for the lower end freeze points like -20F. Our over night temps this year have run around -15F, no issues.
Can't believe they get more than $1.00 a gallon for windshield washer fluid when it is probably 98% water and 2% soap and glycol.
[This message has been edited by Kevin87FieroGT (edited 02-15-2014).]
Report this Post02-15-2014 01:18 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Avoid Pylon and Michelin, made by Pylon.
I have tried them many time and have problem lasting only 1 to 2 months, including premium wiper blades.
I have better luck w/ Bosch wipers.
