  my build thread continued, 3400 swap
my build thread continued, 3400 swap by scott0999
Started on: 09-23-2013 11:39 AM
Replies: 15 (1169 views)
Last post by: ericjon262 on 04-16-2016 08:55 PM
scott0999
Report this Post09-23-2013 11:39 AM Click Here to See the Profile for scott0999Send a Private Message to scott0999Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think my original thread got archived, been a while
https://www.fiero.nl/forum/A...130314-1-084019.html
I've been working on my 3400 swap and yesterday the cradle went back in!
Everything went great. nothing broke and no clearance issues. now I need to make the fuel and coolant lines, couple other misc things.
pics!
[This message has been edited by scott0999 (edited 09-25-2013).]
fierogtlt1
Report this Post09-23-2013 05:50 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's looking great.... Keep up the good work.
jetsnvettes2000
Report this Post09-23-2013 09:44 PM Click Here to See the Profile for jetsnvettes2000Send a Private Message to jetsnvettes2000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finish that thing!!!! SO I can paint it!!!!
Stubby79
Total ratings: 58
Report this Post09-24-2013 11:26 PM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like you've cut off the flange part of the rear manifold and (presumably) welded it up and modified the 2.8's crossover pipe to mate to the two manifolds. Got any pics of the manifold without the wrap on? Is there going to be any issue with the exhaust flow from that manifold?
jetsnvettes2000
Report this Post09-24-2013 11:49 PM Click Here to See the Profile for jetsnvettes2000Send a Private Message to jetsnvettes2000Edit/Delete MessageReply w/QuoteDirect Link to This Post
I saw it and it is done right! Scott is a very Talented fabricator.
Scott!!!!!!! Hurry up and finish so we can start mine!!!!! I also scored a manifold with the turbo flange!
scott0999
Report this Post09-25-2013 12:17 AM Click Here to See the Profile for scott0999Send a Private Message to scott0999Edit/Delete MessageReply w/QuoteDirect Link to This Post
rear manifold is from a 3100. I plasma cut the downpipe flange off and welded a plate in place there. thats the closest thing I could make to a stock Fiero 2.8 manifold. this is actually the 2nd one I've made. first one I did for my cavalier when I did the 1st turbo setup on it, to route the exhaust to the crossover instead. it held up fine for several years, and is still being used on another car right now. I pre-heated the manifold and turned up the welding gas a little more than usual, got a really good weld on it.
the crossover is a stock 3400 one I cut and welded all mandrel bent pipe to it, made the Y-pipe myself too. ground down the welds and used VHT flameproof ceramic on it
carbon
Total ratings: 130
Report this Post09-25-2013 09:52 AM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put a link to your archived thread in your first post!
Good looking work! Makes me want to get moving on my 3500...
scott0999
Report this Post09-25-2013 10:21 AM Click Here to See the Profile for scott0999Send a Private Message to scott0999Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks!
done and thanks!
scott0999
Report this Post09-30-2013 09:34 AM Click Here to See the Profile for scott0999Send a Private Message to scott0999Edit/Delete MessageReply w/QuoteDirect Link to This Post
removed the 3400 SFI from the manifold and powder coated it with wrinkle black
86 toy
Report this Post09-30-2013 11:11 AM Click Here to See the Profile for 86 toySend a Private Message to 86 toyEdit/Delete MessageReply w/QuoteDirect Link to This Post
nice work!! your gonna love your 3400!! i know i like mine.. if you have any questions just ask
--Mark--
Yellow 88 GT 3400 5speed
Need headers? click here!
scott0999
Report this Post10-14-2013 01:11 PM Click Here to See the Profile for scott0999Send a Private Message to scott0999Edit/Delete MessageReply w/QuoteDirect Link to This Post
did a ultrasonic cleaning on the injectors, new orings, filters, ect. did a quick polish on the fuel rail, soldered the multec2 injector ends to the stock injector harness, made a custom chip
easy part of the fuel system is done, now just need to connect to the body side lines. should have made them while the cradle was out but oh well. shouldn't be tooo bad. driver side has plenty of room, just not the back of the engine
Marcopolo
Report this Post04-13-2016 11:49 AM Click Here to See the Profile for MarcopoloClick Here to visit Marcopolo's HomePageSend a Private Message to MarcopoloEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found your thread Scott! Ill be posting some updates on the Fiero on here too!
Marcopolo
Report this Post04-14-2016 01:22 AM Click Here to See the Profile for MarcopoloClick Here to visit Marcopolo's HomePageSend a Private Message to MarcopoloEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need a paint job this summer on that Fiero if you're interested? I know I'm not Scott but I am looking for people to paint it
Marco
lou_dias
Report this Post04-14-2016 09:58 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally! A 3X00 swap that routes the exhaust like a Fiero.
In mine, the previous owner cut out most of the trunk to run the exhaust directly to a cat-conv then around to the muffler. Total hack.
Bridgetown
Report this Post04-14-2016 10:44 AM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice to see another 3400 going together.
I like your solution to the exhaust. If it's alright with you can I include it in the 3400/3500 info thread?
https://www.fiero.nl/forum/Forum1/HTML/091261.html
ericjon262
Report this Post04-16-2016 08:55 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
keep up the good work.
"The day I tried to live, I stole a thousand beggars' change and gave it to the rich."
