  3400 swap with auto, exhaust routing?
3400 swap with auto, exhaust routing? by scott0999
Started on: 08-24-2013 02:45 PM
Replies: 3 (511 views)
Last post by: Bridgetown on 08-25-2013 12:49 AM
scott0999
Report this Post08-24-2013 02:45 PM Click Here to See the Profile for scott0999Send a Private Message to scott0999Edit/Delete MessageReply w/QuoteDirect Link to This Post
has anyone done a 3400 swap with a auto trans? I'm trying to figure out how to route the exhaust and having no luck. the downpipe would be running right into the trans/cradle
I've seen it done with a 5spd, but the auto gives less room there
Dburger
Report this Post08-24-2013 02:54 PM Click Here to See the Profile for DburgerSend a Private Message to DburgerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think Tyler's Toy is a 3.4 auto
FieroJimmy
Report this Post08-24-2013 03:14 PM Click Here to See the Profile for FieroJimmySend a Private Message to FieroJimmyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would block off the factory downpipe location and use a custom crossover to drop it into the stock routing. There should be plenty of room over the trans since you've only got one shifter cable.
Bridgetown
Report this Post08-25-2013 12:49 AM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you look at this this thread.
https://www.fiero.nl/forum/Forum1/HTML/091261.html
The first couple exhausts in the exhaust section should still work with an auto.
