  Totally O/T
  Detected voltage under Fiero body. Wait, what?
Detected voltage under Fiero body. Wait, what? by CoolBlue87GT
Started on: 11-11-2025 12:28 PM
Replies: 14 (138 views)
Last post by: Stingray92 on 11-13-2025 09:57 PM
CoolBlue87GT
Total ratings: 150
Report this Post11-11-2025 12:28 PM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 436
Report this Post11-11-2025 01:36 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to call an exorcist and quick!
Total ratings: 463
Report this Post11-11-2025 03:00 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's... ALIVE!
I'm guessing that it's picking up the wiring to the brake/tail lights, trunk light socket, and maybe the cruise control.
Doesn't the Fiero "switch ground" in order to turn stuff on? If so, there would be 12 volts on the circuit, even if nothing was active, at the moment.
Total ratings: 436
Report this Post11-12-2025 06:35 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
It's... ALIVE!
There's quite a few 'hot at all times' wires in Fieros...well, at least a few that I remember.
Stingray92
Report this Post11-12-2025 07:49 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'd have to double check but on this section of the car I thought only the rear defrost and tail lights ran this side.
Even so if voltage was present it would seem easy enough to check with a multi meter.
Just curious what the model/part number of the detector you used is? I'm not aware of a non contact detector for 12 volts DC or less.
Report this Post11-12-2025 08:30 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doesn't the wiring harness for the taillights run down the passenger side of the rear clip?
CoolBlue87GT
Total ratings: 150
Report this Post11-12-2025 10:09 PM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's APV-600 Non-Contact voltage tester Mfg by AMES Instruments, Found this link : https://www.youtube.com/watch?v=8rxIKdYSy0M
It's for testing AC voltage - Having said that, you can see in my video, it's detecting something w/o the trickle charger on. not sure why, say's it's not for 12 V. It's a mystery.
Report this Post11-13-2025 08:17 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The bulk of the taillight harness does, but the pigtail also extends around that corner of the rear to the side marker lamp, cruise control and rear trunk light.
Stingray92
Report this Post11-13-2025 07:41 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
I suspect your picking up some sort of interference from a light or maybe the power cord that looks to be under the car. I'm not sure what they use for the sensor probably a magnet or something along those lines.
It is odd, and for kicks I took mine and tried several areas with known 12v power and as expected nothing. However when I got within a couple inches of 120v power it picked it up.
CoolBlue87GT
Total ratings: 150
Report this Post11-13-2025 07:58 PM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ding Ding Ding !!! - You were right !! I unplugged the extension cord, that was the reason it was finding voltage. Good eye. Boy that had me stumped. Thank you.
Stingray92
Report this Post11-13-2025 08:07 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
👍you're welcome
Report this Post11-13-2025 08:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
"within a couple of inches ..." Makes sense.
When you put your charger on the ground, your extension cord was at least a couple of feet(!) away. Makes no sense.
CoolBlue87GT
Total ratings: 150
Report this Post11-13-2025 08:54 PM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you look at 1:04 & 1:24 - 1:27 the cord is still right next to the wheel on the floor. That was close enough to allow the 120v signal to be picked up. Off camera, when Stingray92 suggested the cord was under the car, I checked, and unplugged the cord from power, that solved the mystery.
[This message has been edited by CoolBlue87GT (edited 11-13-2025).]
Report this Post11-13-2025 09:12 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
But yes, that's my point! Your voltage detector is at least a couple of feet away from the cord... certainly not "within a couple of inches" as Stingray had observed/commented.
Stingray92
Report this Post11-13-2025 09:57 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
Noise aka magnetic interference or in this case a 120v ac cord was in my opinion close enough to the car to pass through to the sensor.
In industrial control panels we must keep certain distances away between signal wires and 120 volt circuits.
