  Totally O/T
  Garage Floor coverings/barriers? (Page 1)
Garage Floor coverings/barriers? by blackrams
Started on: 04-18-2025 07:33 AM
Replies: 40 (367 views)
Last post by: blackrams on 06-20-2025 08:23 AM
Total ratings: 226
Report this Post04-18-2025 07:33 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
My shop is finally going up next week (if all goes as planned). Getting the concrete completed was its own challenge but, that's done finally.
Researching the different floor sealants/barriers that are out there. I like what I'm reading about the Epoxy based versions but every brand I read about has customer reviews with both good and bad things to say. It seems the "Industrial" versions are more of what I want although they are significantly more expensive. But you only get this opportunity to do it right one time, the first time and I want this to go well and last. I've seen the end results and what the wrong product will look like down the road, I really don't want something that doesn't last (wears) or some product that doesn't protect against stains. I will be applying the surface coat myself. Prefer a clear version but, a colored version won't bother me, I want a chemical protective barrier that does provide some light reflective results.
I'm looking for a brand/version with chemical protections, not just moisture barriers. My concrete contractor recommended a product called Eagle floor coverings but, it's only a moisture barrier.
Recommendations with comments would be greatly appreciated.
TIA.
Rams
steve308
Total ratings: 58
Report this Post04-18-2025 08:41 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.garagejournal.com/forum/
This website has a full section on flooring options.....kind of the Pennocks of garage info.
Total ratings: 226
Report this Post04-18-2025 08:45 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, will check it out.
Rams
IMSA GT
Total ratings: 250
Report this Post04-18-2025 12:24 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of the biggest failures with any of these floors is poor prep. With old concrete, you need to use diluted muriatic acid to prep the surface. Most people skip this step and use some other chemical. Then the floor coating peels up like nothing. In your case, I would imagine that since it's new, you would only have to wash the floor to remove dust. If properly prepped, any of the epoxy coatings will last for many years.
https://armorgarage.com/ind...u=INDSPG-CL-GA&gQT=1
The product above covers 250 square feet per gallon and rolls on. It is a one part epoxy so no mixing.
[This message has been edited by IMSA GT (edited 04-18-2025).]
Doug85GT
Total ratings: 128
Report this Post04-18-2025 12:55 PM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used the Rustoleum Garage Epoxy kit. I made sure to prep the floor. There were a lot of oil stains in the concrete from the previous owner. I used industrial degreaser and scrubbed the floor thoroughly. Then I used my 5" random orbital sander to sand problem areas. Degreased it again then used the acid etch. Be sure you have PPE before using the acid etch. Then I applied the epoxy coating, flakes and clear coat. That was in 2016. The floor has held up well to a lot of abuse. There is paint over spray on it and I dropped a can of PVC primer on the floor. Just so you know, PVC primer will turn your floor purple. It does not matter how stain resistant it is. A few times I have burned the floor when something on fire fell on it or molten metal or slag fell on it from welding. It is a garage floor that I also use as a workshop. It will and does get abuse in my home. None of it is peeling off. It is still protecting the concrete.
Total ratings: 226
Report this Post04-18-2025 10:15 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will be looking at this option closely, thanks for the response. Sounds promising.
Rams
Appreciate the response, have been researching Rustoleum also. Thanks again.
Rams
Rams
Learning most of life's lessons the hard way. .
You are only young once but, you can be immature indefinitely.
[This message has been edited by blackrams (edited 04-18-2025).]
Total ratings: 226
Report this Post04-19-2025 08:27 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Having done some research on this product, I really do like what this product offers but justifying the cost isn't going to be easy............. Yeah, I know. You get what you pay for..................
Rams
IMSA GT
Total ratings: 250
Report this Post04-19-2025 12:06 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rams
It's very pricey and is very strong but I have also done a couple of garages with the Rustoleum and they too came out very nice. I could roll a floor jack around all day long and not damage the surface.
Hank is Here
Total ratings: 101
Report this Post04-23-2025 10:47 AM Click Here to See the Profile for Hank is HereSend a Private Message to Hank is HereEdit/Delete MessageReply w/QuoteDirect Link to This Post
Someone already mentioned garage journal as a resource to review, they are spot on! They have a specific flooring seciton
https://www.garagejournal.c.../forums/flooring.20/
In particular I would recommend reviewing this thread
https://www.garagejournal.c...orks-and-why.545749/
Total ratings: 200
Report this Post04-23-2025 03:23 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
How many bays are you looking to get? Will this be in addition to an already existing 2-car garage on your home?
Total ratings: 226
Report this Post04-23-2025 03:40 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
My current home has a three car garage.
This shop (currently being put up) is 30X40 feet. One single 12 foot wide 8 foot garage door.
Two walk through doors, one in front and the other in the rear. 12 foot open lean to (roofed on the rear of the building.
I want to apply epoxy to the floor before moving my tools and toys in on it and get my lift installed..
Rams
Report this Post04-23-2025 03:41 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
In industry,in used STONE HARD.
It held up to forklift traffic and sliding metal skids across the floor, as well as strong acids and alkalines.....
You probably don't need that much protection, however.
Or the price tag!
Total ratings: 226
Report this Post04-23-2025 04:17 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oops
Rams
[This message has been edited by blackrams (edited 04-25-2025).]
cliffw
Total ratings: 292
Report this Post04-24-2025 05:15 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paint.
Total ratings: 226
Report this Post04-24-2025 07:05 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or the price tag!
Yeah, I checked the Stone Hard coating out, definifely won't be any forktruck traffic and out of my price range anyway.
Originally posted by cliffw:
Paint.
Paint isn't an option, simple foot traffic will wear it down to expose the concrete. Mostly looking to achieve a chemical and lubricant barrer. Yeah, I spill things.
Rams
Total ratings: 226
Report this Post04-24-2025 07:25 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Feb 2003
From the article:
Just please, for the love of your garage, don’t take advice from the guy in the orange or blue apron.
LMAO!!!
Rams
Total ratings: 226
Report this Post04-27-2025 06:56 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, back to the ole drawing board. Thought I found a sealant for my new garage floor with good ratings that would protect my new concrete floor from lubricants, moisture and chemicals while providing very good wear resistance.
Was about to order but thought I'd check with a friend since he's done this before. Even though the product was supposed to be 15 times tougher than epoxy but priced within my budget, my friend reports that he picked and applied the same product to his new concrete floor and although it holds up with vehicles rolling over it in a straight line, if the steering wheels get rotated while parked, the barrier rolls up as the tire moves. He said he followed all the instructions in prep and application.
As I said, back to the search. The electrician is coming by today to tell me what he recommends for my purposes. Scaling back on some things might be my only option. I keep telling my Texas friends I'm available for adoption but.......................................
BTW, this is what I thought I was going to go with in case you're interested:
Rust-Oleum 293515 RockSolid Polycuramine Garage Floor Coating, 2.5 Car Kit, High Gloss Tan
Rams
[This message has been edited by blackrams (edited 04-27-2025).]
cliffw
Total ratings: 292
Report this Post04-29-2025 07:51 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will say it again. PAINT.
I used paint all the time in the oil fields. A rough environment.
This is what I used.
paint / part a / part b
https://www.garagefloorcoating.com/epoxy-mixology/
https://www.blastone.com/7-...ctly-mix-your-paint/
Total ratings: 226
Report this Post04-29-2025 08:53 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paint isn't an option, simple foot traffic will wear it down to expose the concrete. Mostly looking to achieve a chemical and lubricant barrier. Yeah, I spill things.
Rams
The products I've been looking at don't refer to themselves as "Paint". But, I get your point and will continue my research. Thanks for the response.
Rams
GT-X
Total ratings: 106
Report this Post04-29-2025 09:09 AM Click Here to See the Profile for GT-XSend a Private Message to GT-XEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whatever you choose, do a lighter, solid color. I had the misfortune of being stuck with a shop floor that had those tossed in speckled chips and finding that nut/bolt you just dropped was miserable.
Total ratings: 226
Report this Post04-29-2025 09:13 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Initially planned on a clear coating or a light-colored version that would reflect light back up. Never planned or wanted the sparkly chips to begin with. Thanks for the response.
Rams
Total ratings: 436
Report this Post04-29-2025 09:47 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
My father had a 7 car auto shop from 1956 until he fully retired in 1989 and never had anything but bare concrete. I grew up working in it and I can say that spilled oil soaked right in over the years and made a perfect moisture barrier. Didn't need no stinking storebought coverage/barrier.
Total ratings: 226
Report this Post04-29-2025 12:15 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Were such coatings/barriers even available back in "56"?
I believe the toxicity/stink goes away pretty quickly.
Rams
Total ratings: 436
Report this Post04-29-2025 02:18 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
I never noticed any stink and I rolled around under many a car, both on a creeper and without. As far as reported 'toxicity', I'm still here and my father lived until almost his 90th birthday.
Total ratings: 226
Report this Post04-29-2025 06:50 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don,
I should have been more precise. I was talking about the toxicity and odor of Epoxy. It disappears in as little as 6 to 8 hours depending on the product chosen.
Rams
IMSA GT
Total ratings: 250
Report this Post05-05-2025 09:39 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
This should be perfect. The combination of Urethane and epoxy plus polyurea makes it bulletproof. Not a bad price either. Not sure why your friend had issues with his floor.
[This message has been edited by IMSA GT (edited 05-05-2025).]
Total ratings: 226
Report this Post05-05-2025 09:41 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
While I am strongly leaning toward this, I'm still researching the prep required.
Rams
Report this Post05-06-2025 09:00 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
A rough surface is critical for good adhesion, as is completely removing the material used to etch the concrete.
Rinse, rinse, rinse and dry, dry, dry!
Then blow any dust off of the surface with a leaf blower or double filtered compressed air.
[This message has been edited by olejoedad (edited 05-06-2025).]
Total ratings: 226
Report this Post05-06-2025 09:09 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Obviously, rushing into this is not my style.
Rams
hnthomps
Total ratings: 50
Report this Post05-30-2025 10:42 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ron/Rams,
A high quality polyurea coating includes diamond scraping of the floor, polyurea coating, seal coat, color chips if you want them, and a lifetime warranty. Typically costs around $8-$9 per square foot installed. the coating takes 48 hours to funny cure to the point where you can put vehicles or machinery on it. The price for lesser quality epoxy flooring materials is in the $6-$7 per foot range. The company I am currently dealing with is Renuity and they have been around for a while.
Nelson
Total ratings: 226
Report this Post05-30-2025 11:43 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by hnthomps:
Ron/Rams,
Nelson
Nelson,
Thanks for that information. Hoping to get that floor coating applied a couple of days before I install the two-post lift. Thanks again.
Rams
Total ratings: 226
Report this Post06-07-2025 07:23 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally made the decision.
Rust-Oleum Rock Solid.
Bought enough for a 1500 sq. ft. floor, my shop is only 1200 sq. feet but I'll lay it on thick in the work and drive areas. KInd of pricey in my opinion but, I don't want to have to do it again, ever.
Rams
[This message has been edited by blackrams (edited 06-07-2025).]
Total ratings: 226
Report this Post06-16-2025 09:01 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
After my purchase of the Rock Solid floor coating, due to other priorities, the shop floor had to wait. Regardless, I finally got to work on that project a few days ago. Everything I've read said that "Prep" was the most important part (along with a smooth application of the actual coating). The product I bought is a complete kit with Citric Acid, those flakes (that won't be used) and the actual coating along with the application rollers.
The directions were very clear and I followed them to the letter. What I didn't expect was having to spend two days trying to get all the slurry and dust off the concrete off the now prepped floor. The directions clearly stated that the coating should not be applied if one could swipe your fingers or hand against the floor and get any dust on that appendage. I've swept, blown out, washed, pressured washed and mopped that floor numerous times and it seems accomplishing the dust free floor is almost impossible. Yeah, I'm probably being anal about this but, I want it right. Anyway, today the shop floor gets a final mopping and once that has dried, the coating goes on.
I could have hired this project done, one quote I got was over $3K. But, I'm cheap.
Rams
CoolBlue87GT
Total ratings: 150
Report this Post06-16-2025 09:34 AM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rams
Looking forward to seeing photos or video of the process. I may want to do my own garage.
Good luck with it.
[This message has been edited by CoolBlue87GT (edited 06-16-2025).]
cliffw
Total ratings: 292
Report this Post06-18-2025 11:16 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rams
Ron, perhaps vacuuming it would help.
Total ratings: 226
Report this Post06-18-2025 11:54 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, tried that also, just left it off the list. Due to what the instructions said, I elected to do the final step (coating the floor) after dark. The instructions (which I followed to the letter) stated that sunshine affected the curing process. This stuff is too expensive to take a chance so, I started rolling the floor coating about 9:00 PM last night, got finished a little after midnight. The coating is no longer tacky but, still a bit soft so nothing else will happen for a few days so I don't screw this up. But, it does look really good. Has the color I wanted and almost a mirror finish reflecting light.
Won't be posting pictures here but, I'll send anyone interested pics via text if they really want to see the whole process. Just sent me a phone # via PM.
Rams
Total ratings: 226
Report this Post06-19-2025 10:50 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
For those who may be interested:
Completed coating.
My shop floor half way through coating and when it's been completed and done. As you can see, the etching process makes the floor look like crap.
For those who may wonder, the completed floor had been curing for about 8 hours when the first photo was taken. Those bright spots are a reflection of the ceiling lights on the floor. While my efforts were not perfect, I'm happy with the end results. The one problem I could not overcome was those dang insects that kept landing on the wet floor surface. Some of them are permanently entomb in the Rock Solid. It is, what it is.
Next, onto the two-post lift installation. Will wait a few days on that to ensure the Rock Solid is completely cured. I put on a pretty thick coating.
Rams
[This message has been edited by blackrams (edited 06-20-2025).]
Total ratings: 226
Report this Post06-19-2025 07:34 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just an offer but, I did follow the advice and did not use the "Speckled Chips" so, if you're needing any, just send me your address and I'll send you six unopened packages. Other than throw them into the garbage, I have no idea what else to do with them.
Rams
CoolBlue87GT
Total ratings: 150
Report this Post06-20-2025 07:56 AM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow that came out really good. Not using the "Speckled Chips" was a good idea.
Glad it covered the etched floor pattern, as people have said, the prep work is the most important part.
Total ratings: 436
Report this Post06-20-2025 07:57 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have no idea what it is in the garage as it was here when we bought the place 3 years ago but The floor of my garage was coated with 'something'..what, I do not know. According to neighbors, at one time, it was also afterwards completely covered in some kind of pads that left little round suction cup like spots on the sprayed or rolled down covering when the previous owner removed the padding. The covering is pretty durable but the downside is that any time I or wife comes or goes and turns the steering wheel more than a few degees it leaves ugly black tire marks on the gray surface. Hopefully, your covering won't do that.
