  Totally O/T
  Are you frustrated with car jumpstarters?
Are you frustrated with car jumpstarters? by Kitskaboodle
Started on: 04-02-2025 04:50 PM
Replies: 17 (204 views)
Last post by: Doug85GT on 04-12-2025 01:31 AM
Kitskaboodle
Report this Post04-02-2025 04:50 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I’ve been through several car jumpstarters now and they always fail for the same reason. (charging issue) Every single one I’ve bought (3 different brands now) start out ok, you get a few jumps out of them, and then they start to misbehave during charging. (i.e. they will not fully charge to 100% or they will not take a charge at all or they will begin to take a charge and then simply shut off) 🙁 I’ve never had one that even lasted past three months. I’ve even returned/exchanged them but the replacement does the same thing.
Here’s the thing: In theory and concept and promises they’re great! 😊 But on reality they come up short and are a disappointing product. I will not but these anymore until the battery charging issue is resolved.
That being said, am I the only one who has major issues with this product? These jumpstarters are a huge letdown. 🙁
Lastly, is there an easy way to somehow modify it so that it will take a full charge? What is the issue, the battery itself or the electronics?
Kit
P.S. Here’s my older jumpstarter (it’s about 2 years old now) It has a 5 bar graph charging meter/ indicator. It will charge only to a bar and a half.
Report this Post04-02-2025 06:18 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You've been through three of 'em? My question would be... why such a dire need for a jump-starter? Seriously! We've all killed a car battery at one time or another by accidently leaving parking lights or something on... but it's usually a pretty rare occurrence.
I also don't like the idea of my car's alternator feverishly trying to recharge a dead battery after the engine's been jumped to start.
Having said that, I do make use of my battery chargers if/when I haven't driven one of my cars for awhile... but I've never felt the need to have a jump-starter on hand.
A friend of mine had a jump-starter that no longer worked, so I offered to take a look at it for her to see if I could resurrect it. No chance. Even when I connected its battery to my own charger, it was deader than a doornail.
Total ratings: 399
Report this Post04-02-2025 06:19 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got one based on feedback. It was not a small unit and had substantial battery life. When I first got it I could jump the car 3 times from a dead battery. That didn't last long.
I wish there was a system you could install in your car that would have an extra battery that would charge up during driving but disconnect when you shut the car off.
Then if you try to start the car and it senses the voltage is low it kicks in a boost. Something away from the parasitic drain of the main battery.
Edit
Heck even a "smart" battery
Na they wont do that because you wont be buying batteries every 3 years.
I remember my first car, the battery was 10 years old when I got it and was still good 5 years later when I sold the car.
[This message has been edited by Jake_Dragon (edited 04-02-2025).]
Kitskaboodle
Report this Post04-02-2025 06:41 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I knew the question would be brought up about why do I rely on jumpstarters so much? Well, for one my cars sit a lot (I really only have 1 daily driver) and two, it’s more convenient to pull out the jumpstarter (that you typically store right in your car anyways) and use it for a quick jump rather than to pull out my Schumaker home charger and having to run an extension cord into the garage to my workbench. Also, they are handy for emergencies like leaving your interior light on in your car overnight, etc. (peace of mind) and lastly most of them are part “power bank”, so you can use it on the road if you phone battery is low/ dead. Kit
[This message has been edited by Kitskaboodle (edited 04-02-2025).]
IMSA GT
Total ratings: 250
Report this Post04-02-2025 06:46 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would go with one that has a larger battery capacity. That way you have some wiggle room if a cell goes bad. With the smaller compact units, when a cell dies, half of your voltage is gone.
https://www.amazon.com/Clor...DKIKX0DER&gQT=1&th=1
At least with this one, I believe it uses a 12volt 22ah lead acid battery that you can replace instead of buying a new booster pack.
[This message has been edited by IMSA GT (edited 04-02-2025).]
Kitskaboodle
Report this Post04-02-2025 07:42 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Imsa, the one in your link is the old school lead acid battery type. They’re ok but they have their negatives also. (bulky size, heavy weight abs they too eventually die) And, most people keep those around the house, garage, farm, etc and NOT so much in the car for backup. They’re also more expensive.
Like I mentioned earlier, on paper the small “brick” shaped jumpstarters are far more appealing (price, convenience, compact size, etc) but buying them is like going down a rabbit hole.
They can send a man to the moon. Why can’t they figure out how to make a jumpstarter that will charge properly? Inquiring minds want to know…
Kit
Total ratings: 399
Report this Post04-02-2025 07:51 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The issue is always the battery.
makita battery car jump starter has caught my eye because I have several battery tools laying around and several portable batteries.
For me I got my first one because my car would sit all winter and the apartment didn't have power outlets for a trickle charger.
Now I work from home and I get so busy I forget to go drive the car around
Report this Post04-02-2025 07:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the type of jump-starter my friend had that I tried to resurrect. When I discovered that its battery was toast, I priced a replacement battery... and subsequently informed my friend that her jump-starter wasn't worth fixing.
Total ratings: 463
Report this Post04-03-2025 03:47 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought one of the $89 Harbor Freight jobs, back in the fall. I've used it several times to start cars - one of which was a Fiero with a completely dead battery. (Battery tender wouldn't even bring it back, after the jump start.) But we use it around the farm to jump start mowers and SxSs that don't get driven much.
I've had good luck with it. Even bought one for a relative.
https://www.harborfreight.c...ower-bank-59527.html
[This message has been edited by Raydar (edited 04-07-2025).]
CoolBlue87GT
Total ratings: 150
Report this Post04-04-2025 12:13 AM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the same problem you had, lots of junk out there.
A few months ago I picked up from Walmart a GOOLOO GE1500 jumpstarter , I didn't expect much, it really works great.
Time will tell how long it will last.
I have 5 battery tenders hooked up to vehicles in my garage, picked up the jumpstarter to keep in the daily driver, have used it a few times to help coworkers with jumping their cars.
[This message has been edited by CoolBlue87GT (edited 04-04-2025).]
RWDPLZ
Total ratings: 305
Report this Post04-04-2025 08:40 AM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had excellent luck with the older style jump boxes, and just replacing the internal battery every few years.
shemdogg
Report this Post04-05-2025 11:17 AM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ive tried those mini jump starters but theyre only good for that. I had one of these and got another after getting rid of the mini one.
https://www.schumacherelect...table-power-station/
These are awesome and very handy. When the lead battery dies I get a lithium from amazon and I have the jump power of a mini w all the goodies in the jump box. We started using these to jump start jetskiis at the lake a long time ago. I like this brand and style, very useful
shem
Kitskaboodle
Report this Post04-05-2025 01:01 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
John, I hate to say it but the reviews of the one you’re recommending has very poor reviews. I find that their customer service says the typical response: “We’re so sorry for your experience…please contact us at your earliest convenience”. Ya, right. 😀
Here’s a concept: why don’t you go back to your company drawing board and fix the root cause of your charging issues? Oh, and in the meantime, stop selling known defective products. 🙁
Kit
[This message has been edited by Kitskaboodle (edited 04-05-2025).]
Report this Post04-05-2025 06:43 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by CoolBlue87GT:
A few months ago I picked up from Walmart a GOOLOO GE1500 jumpstarter...
I wouldn't buy anything named GOOLOO just on principal alone.
IMSA GT
Total ratings: 250
Report this Post04-05-2025 07:51 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
I bought one of the $89 Harbor Freight jobs, back in the fall. I've used it several times to start cars - on of which was a Fiero with a completely dead battery. (Battery tender wouldn't even bring it back, after the jump start.) But we use it around the farm to jump start mowers and SxSs that don't get driven much.
Harbor Freight hit a homerun with that unit. Every once in a while they have a vendor that knows how to make a good product and that's one of them.
pokeyfiero
Total ratings: 306
Report this Post04-07-2025 10:48 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://a.co/d/6Tb6EqD
Ohly had it a couple months but so far under heavy use it is a power house.
Kitskaboodle
Report this Post04-09-2025 09:25 AM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the link Andrew. I checked it out and the specs look fine.
However, because of the nature & reputation of this product, there ought to be a special section of reviews on Amazon that give reviews solely on long term use. (like over a year or more) I bet most of these reviews are from at least less than 3-4 months ownership and because of this you don’t see anyone complaining about charging issues. (which I feel is all too common with this product) Like I mentioned earlier in my thread, they all “behave” out of the gate but 3 months or so down the road, they start to develop charging issues of different kinds.
One last thing and a word of advice to ANYONE buying ANYTHING on Amazon: when checking reviews for feedback, start at the bottom first!! Amazon is far more sneaky about influencing your decision than you think.
You’ve heard of the VW “diesel dupe”? Well, Amazon has their own dupe as well. It’s called the “Positive reviews on the top” dupe. 😀
Kit
[This message has been edited by Kitskaboodle (edited 04-09-2025).]
Doug85GT
Total ratings: 128
Report this Post04-12-2025 01:31 AM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have used two of them. The first one the battery pack started to swell so I stopped using it. The second one is still going strong. If it fails than I am not going to buy any more that use lithium ion batteries. I'll look for the larger ones that use a sealed lead acid battery like you get in a computer UPS.
