  Totally O/T
  Stupid Stupid
Stupid Stupid by cliffw
Started on: 04-13-2023 10:20 AM
Replies: 12 (255 views)
Last post by: Valkrie9 on 04-16-2023 11:57 PM
cliffw
Total ratings: 292
Report this Post04-13-2023 10:20 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need to move a vehicle, perhaps let it propel itself on to a tow away trailer. It runs, if you put gas in the carb throat. Fuel delivery issue.
I put fuel in the tank. No go.
I need a quick fix and do not want to crawl under the truck to repair it. With my luck, a fuel pump in the tank.
I price electric fuel pumps. Damn, am I that old ? Now they are $50.00+ on the cheap end.
I own a tow chain and a come-a-long.
Total ratings: 436
Report this Post04-13-2023 11:11 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
At what now seems like a million years ago, I saw my father put a small gas(oline) tank on the hood of a car with a hose going down to the carb fuel inlet. I'm thinking it was something like a 50s Nash. That was just to see how well the engine ran and to drive it from a back lot up to his shop. The tank looked like it may have come off an old lawnmower or garden tiller.
If the carb needs pressure at it's inlet beyond what gravity would provide, then this is a no go.
css9450
Total ratings: 86
Report this Post04-13-2023 11:28 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
What kind of vehicle is it? Can you get it to move by just cranking the starter without pressing in on the clutch? I briefly owned an old Jeep CJ-7 and on more than a few occasions I just used the starter to hostle it around the driveway when I needed to get the other car out.
Total ratings: 200
Report this Post04-13-2023 01:56 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Like MJ said... if it's a carbed vehicle or a low-PSI fuel injected throttle body system, you can simply buy an external tank from Summit (or even Amazon), and wire up a "pusher pump." They sell them in various PSIs... from 2-4-6-8-10, etc... and you just wire it to hot, and let it go.
That's "basically" how most VW buses are. The "pickup," if you can even call it that, in a VW Bus fuel tank, is basically just a sock that's dipped into a tank, with a line that runs up and out, and then it connects to the mechanical pump, which almost everyone replaces with a 12v pusher pump that they wire in-line with the ignition coil. Super-easy.
If you watch Vice Grip Garage on YouTube, this is what he does on half the cars he gets running (that have been sitting for decades).
Really, if you wanted to do it ghetto, you could just wire a pusher pump, and have the feed line just be a long flexible fuel line that feeds into a 5-gallon Jimmy can that you buy from Harbor Freight for $15. Pusher pumps are like $20 bucks.
Here you go... 3-6 PSI (works for basically all carbed cars): https://www.amazon.com/JDMS...etrol/dp/B00L8IHM9K/ $10 bucks.
cliffw
Total ratings: 292
Report this Post04-13-2023 02:00 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you.
It's a ??1989 plus, maybe a 1994??? Nissan automatic. That Hail Mary will not work. I have used it before, as well as using the starter to start my 7.3 turbo diesel pick up when I had a broken clutch fork.
Again, thank you.
I thought all old school carberators need at least 8psi of pressure to fill the carb bowl, so the carb's accelerator will work and keep working. The carb's float valve halting the flow when there was enough.
Thanks for the idea. Perhaps I can use a boat's fuel primer bulb to get done what I need to do. It's not mine. If it was, I would fix it.
Total ratings: 297
Report this Post04-13-2023 02:20 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get a couple neighborhood kids to push it. Give 'em 5 bucks each. Still above minimum wage for the time involved.
Problem solved.
Aint it great being management ?
[This message has been edited by MidEngineManiac (edited 04-13-2023).]
Total ratings: 106
Report this Post04-13-2023 02:26 PM Click Here to See the Profile for williegoatClick Here to visit williegoat's HomePageSend a Private Message to williegoatEdit/Delete MessageReply w/QuoteDirect Link to This Post
For a couple hundred bucks, you can get a decent electric wench, and it will always come in handy.
Total ratings: 400
Report this Post04-13-2023 02:29 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
how brave dumb are you?
Vaper 19419 Red Spot Spray
This post was intended as humor, if you or someone in close proximity to you are missing eyebrows tomorrow I take no responsibility.
cliffw
Total ratings: 292
Report this Post04-13-2023 02:31 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Todd. I know pumps. They need suction and discharge which the pump creates. Some pumps are designed to push, some to suck. Gravity feed could work, does work, for certain purposes.
That Amazon pump is exactly what I was looking for. Thank you. I don't remember where I searched. I figured they were all expensive because most modern fuel systems need 50psi or so.
Total ratings: 200
Report this Post04-13-2023 03:56 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like a "sucky" situation!!!
Total ratings: 436
Report this Post04-14-2023 10:09 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, but depends on your idea of 'old school'.
All the carb ever saw or needed was whatever was in the carb's fuel bowl. The only reason for the pump was because the factory gas tank sat below the level of the engine. (I've owned lots of farm equipment where the gasoline fuel tank was above the engine and no fuel pump was present or required.)
For acceleration in automobiles, the initial surge of power came from a little linkage operated plunger type pump inside the carb. Squirted a single pulse of fuel into the carb throat but venturi effect as the needle(s) was/were were lifted and butterfly opened took over and did the acceleration after that.
Valkrie9
Report this Post04-16-2023 04:41 AM Click Here to See the Profile for Valkrie9Send a Private Message to Valkrie9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Remote gas tank.
Watched one of his episodes when he drove it a few hundred miles home, the tanks in the passenger seat, successfully.
So, now I read this post afterwards, same videos that interest me.
[This message has been edited by Valkrie9 (edited 04-16-2023).]
Valkrie9
Report this Post04-16-2023 11:57 PM Click Here to See the Profile for Valkrie9Send a Private Message to Valkrie9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Valkrie9
Member since Jan 2021
A quote
Gonna get like, way worse, real soon.
Get ready for a crunch far deeper, worse than '29.
Grow some zucchinis, get a windmill. ~ Bill Burr
