  Totally O/T
  Electrical tape recommendations
Electrical tape recommendations by Kitskaboodle
Started on: 08-27-2022 11:38 PM
Replies: 14 (278 views)
Last post by: Kitskaboodle on 08-29-2022 09:29 PM
Kitskaboodle
Report this Post08-27-2022 11:38 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have been very frustrated with most brands of electrical tape. Most of them unravel after you wrap them tightly around wires, plastic looming, etc.
I have tried many brands and few stay tight and in place.
I always thought Scotch black electrical tape was the go to standard but even this brand unravels / loosens up.
Your recommendations for a good electrical tape that actually stays wrapped around wires tightly?
Thanks, Kit
[This message has been edited by Kitskaboodle (edited 08-27-2022).]
TheDigitalAlchemist
Total ratings: 94
Report this Post08-28-2022 12:45 AM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's one made by 3m that does a good job, there's one I've used that has almost no sticky adhesive yet if you stretch it, it sticks to itself very well. it's unbranded.
Gaffer's tape does a good job of stayin' put, as is Gorilla tape, but that's more of a "duct tape" thang.
But I feel like the tape from back in the 80's just did its job better.
Total ratings: 436
Report this Post08-28-2022 01:21 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Scotch Super 88.
Total ratings: 398
Report this Post08-28-2022 04:29 AM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use gorilla tape, but a good quality shrink wrap is better than any tape unless you have to undue the repair when you get home
[This message has been edited by Jake_Dragon (edited 08-28-2022).]
Total ratings: 297
Report this Post08-28-2022 09:03 AM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use buck-store vinyl tape, then top it off with this stuff. Generally solder and heat-shrink where I can, though.
https://www.amazon.ca/SAVIT...%2Caps%2C1674&sr=8-8
Total ratings: 460
Report this Post08-28-2022 09:23 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Scotch Super 88.
Yes. This.
Scotch makes several different "grades". This is worth the expense.
Gaffer's tape is good too. Once it's stuck, it stays there. I'm not sure about how waterproof it is, though.
I've had to return several large packages to flea-bay or amazon. I always use gaffer tape for the returns.
I even had one vendor to thank me for packing my return so well.
[This message has been edited by Raydar (edited 08-28-2022).]
RWDPLZ
Total ratings: 305
Report this Post08-28-2022 10:15 AM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actual wire harness automotive tape. My favorite is Nitto Denko, but there are a number of equivalents made by Elliot Tape, tesa, Great Lakes Tape, etc. The problem is they're sold in bulk in boxes, not generally to the public, but you can find them on eBay and other sites.
Here's a good one, Nitto 2101TVH
https://www.ebay.com/itm/30...JAV7I7FNuhohR7Lmd3Uf OR9J3RfIrnInym1RIqWM0ikwjpy%2FIiWtdAtLoy%2Fe2tb%2F3HfB%2FXbTFkAQBkIYQFcJwt095fDQ%2FrZyy9SdRAUW6N%7Ctkp%3ABk9SR8Do_svcYA
Specs from the catalog on page 12:
https://www.nitto.com/sea/e...le/AUTOMOTIVE_en.pdf
Other autmotive tapes:
https://www.egitape.com/pro...category/automotive/
mike-ohio
Report this Post08-28-2022 10:57 AM Click Here to See the Profile for mike-ohioClick Here to visit mike-ohio's HomePageSend a Private Message to mike-ohioEdit/Delete MessageReply w/QuoteDirect Link to This Post
I usually use F4 tape.
Total ratings: 436
Report this Post08-28-2022 11:09 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
The non-scotch type tapes mentioned in this thread.........
What are the electrical insulating values of them?
(F-4 states 8kv and in the recent past I've had voltages that high (and higher) on my electric fences before but have never seen any tape that wouldn't leak voltage thru it in wet weather)
[This message has been edited by maryjane (edited 08-28-2022).]
ls3mach
Total ratings: 222
Report this Post08-28-2022 04:15 PM Click Here to See the Profile for ls3machSend a Private Message to ls3machEdit/Delete MessageReply w/QuoteDirect Link to This Post
I sell stainless steel. I wrap stainless tubing in bulk cheap crap.
I don't believe in electrical tape as a permanent solution for my task or electrical work...
Total ratings: 297
Report this Post08-28-2022 04:19 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stretch tape is silicone rubber, so whatever rating silicone is, and self-sealing. Plumbers use it to fix leaks and I 1st got into it working on slushy/ice-cram machines where the condensation is a BEAACCHHH to deal with. It solved a lot of problems for me, but nowhere near 8kv either.
Report this Post08-28-2022 06:24 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Car harness wiring wrap is Not Electrical Tape and does Not uses adhesives or a least not like "normal" tapes.
First problem people use E-tape including best products like 3M Super 33+ & Super 88 is you pulled the tape very tight. Then you often try to wrap long sections.
Just that 2 issues and the E-tape tries to return original shape and nothing is going to stop that more so when harness is bent often several to many times.
Plastic Wrapping Is an outgrowth of Cable Lacing using "string" to bundle wires. There are "rules" for tension, to start, wrapping, allow wires to exit at random points and end the wrap. If you fail any step then the wrap will fail and likely soon.
I think Eastwood.com and some others carry proper car wrapping "tape" in single packs. Not digging thru current offers.
Even for Electrical work where E-tape is made for... Can have same problem.
People pull tape way too tight, worse not having enough overlap and then tries to self unwrap starting at the end.
Many use typical 3/4 tape to wrap large spaces... Is a reason 3M and other offers 1" to 2" tape so you don't wrap a whole pack or more of narrow tape.
Cheap tape is even worse because of the cheap "glue" that fails all by itself and often makes a huge mess doing so. Worse when is outdoors or in high heat places.
When you don't see a CSA UL etc ratings on the pack, core or both... Do Not Buy the crap. Example: 3M Super 88 have CSA -10 to 105°C, UL 539H Insulated Tape, and others. Even tho product is max 600v and 80°C
3M Super 33+ is 7mil thick 3/4" to 2" wide & Super 88 8.5mil thick only in 3/4" wide I've use a lot of both... Sometime thicker tape isn't good or need bigger width.
RWDPLZ
Total ratings: 305
Report this Post08-28-2022 08:14 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't say wiring wrap, I said tape. If you'd bothered to look at the specs I'd posted, you'd see it does in fact use adhesive.
The difference between hardware store electrical tape and good tape is mainly the adhesive. Why don't you see good automotive-grade tape at auto parts or home improvement stores? The tapes you see for sale are produced at extraordinarily low cost, and are 'good enough' for most home applications. As a result, the market hasn't demanded a better tape. Anyone seeking a better tape will usually quickly find them, albeit at an increased price and lack of immediate availability.
There's a reason these catalogs have dozens of different tapes for different applications. OP said wiring and plastic looming, which probably means automotive, not UL household.
You can see a typical automotive electrical tape installation here:
Towards the end of the video: Look at the way she wraps it around the bundle, not stretching it, using a "half overlap" (half the width of the tape) technique. I've seen little old ladies that do this every day for years do this at a speed that surpasses most automated processes when you take setup into account, on all but the longest spans.
Despite long spans, the standard 19mm width tape I gave an example of in the previous post is typically used, due to versatility and economies of scale in mass production. Other tape types will be used where applicable, depending on heat resistance, potential exposure to liquid, NVH concerns, or potential for abrasion. Harness coverings (hard tubes, soft tubes, channels, corrugated tubing, etc) are used in conjunction with the tapes where applicable.
Here, you can see a wider cloth type tape. He's taping larger spans in an area where NVH is probably an issue.
ls3mach
Total ratings: 222
Report this Post08-29-2022 12:06 AM Click Here to See the Profile for ls3machSend a Private Message to ls3machEdit/Delete MessageReply w/QuoteDirect Link to This Post
Edit.
Thanks.
[This message has been edited by ls3mach (edited 08-29-2022).]
Kitskaboodle
Report this Post08-29-2022 09:29 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I was referring mostly to automotive wiring / loom applications.
I ended up buying the 3M Super 88. 😀
Thank you all for the informative input!
Kit
[This message has been edited by Kitskaboodle (edited 08-29-2022).]
