Lots of options, I like the vortex and its just a pump that swirls the water. Even if you don't have the container where you can see inside it would still look cool from the top. I saw this video before and thought it would explain pretty well and demonstrate how you can accomplish your goal. Don't burn off your eyebrows. |
Yeah, almost too late for that.
Actually, I had it figured out but couldn't find all the different hardware I needed to make it work. I wanted the gas to come up from the center of the barrel which required an elbow and I couldn't find one the proper size and length to go through the barrel metal and still use a gasket to contain the water without leaking. The other challenge was finding a 3/8ths beveled union on both ends to connect the two hoses I wanted to use. You'd think most stores that sell grills would have that in stock. Lowe's, Home Depot, my local hardware store didn't. Finally found an Ace Hardware store that had what I needed. I bought an additional 10 foot hose because I didn't want my propane bottle sitting right next to the open flame.
It works well in a light breeze. Any breeze more than about 10 mph though and the wind carries the flame away from the source propane. Of course, that's with the water completely up to the rim of the barrel top. I'm thinking that if I drop the water level about a third and give the flame a bit of protection from the breeze it'll work well.
Oh, forgot to mention, I cut the barrel down to the bottom rib just cause I thought it would look better. Then placed it on top of one of those barrel dollies. Works just fine.
The wife is all tickled and can't wait for me to fire it up at night. This was a good idea, at least until I burn the house down.
Edited: Fired it up after dark, absolutely glorious. She loves it and now wants a brick version. When will I learn my lesson....................
I tried to post a video of the result but, can't seem to make it work. If someone else would like to do that, send me your contact info and I'll try sending it to you.
Rams
[This message has been edited by blackrams (edited 03-28-2021).]
