  Totally O/T
  Ar15 pistols and the law or "common sense" gun control.
Ar15 pistols and the law or "common sense" gun control. by dennis_6
Started on: 07-23-2017 03:58 PM
Replies: 10 (298 views)
Last post by: dennis_6 on 07-26-2017 04:36 PM
dennis_6
Total ratings: 115
Report this Post07-23-2017 03:58 PM Click Here to See the Profile for dennis_6Send a Private Message to dennis_6Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is precisely why the Atf needs disbanded and the Nfa repealed.
The BATFE has been telling NFA applicants that their approvals could take as long as 15 months from the date their application enters the “pending” status. Those who have been through the process before know that it can take a few months to even get to the pending status. These new revelations coupled with recent gear developments have me reconsidering my stance on AR-15 pistols.
I wouldn’t say that I am anti-AR pistol and I also wouldn’t say that I think they are a great idea. I guess that I am somewhat agnostic toward them. However, what always bothered me was casual way that they were written off by many “experts” who sneered that they were toys without ever really backing that up with actual data. So, in an effort to find out what is really up with AR pistols, I am planning on building one and putting it through the wringer. I’ll report back with quantifiable data in regard to how they perform against a similarly configured rifle. That sort of project takes some time and while I have been preparing for it, I came across a lot of misinformation about AR-15 pistols that I would like to set straight in this article.
Photo courtesy of AR15News.com
Before I get too deep into the weeds, I should say that am not a lawyer. This is not legal advice. You should also familiarize yourself with your local laws to ensure compliance. Understand that while many BATFE opinions are cited in this article, they are just that – opinions – which are apt to change.
Paperwork
The 4473 form that you complete at the point of purchase seems like a good place to start since it is where you AR pistol adventure will start. It is no longer necessary to have the lower transferred to you as a handgun. Receivers are now transferred as a “receiver.” This is stated directly on the current form 4473. You can build the receiver into whatever you like as long as it meets legal definitions of a handgun or rifle.
Cite: BATFE Form 4473
Once a Rifle, Always a Rifle
The BATFE has made it very clear that once a receiver is built into a rifle, whether by a factory or by you, it is always a rifle and converting it to a pistol is illegal. However, it is perfectly legal to build the receiver into a pistol first and then convert it to a rifle. If the receiver is built into a pistol first, you can configure it back and forth from handgun to rifle and back again as much as you want. However, you must be vigilant to ensure that a shorter than 16″ barrel is never on the receiver at the same time as a stock.
The proper order for converting an AR pistol to a rifle is to remove the short barrel (usually done by removing the entire upper receiver group), installed the 16″+ barrel (usually done by installing an entire upper receiver group), and then installing the stock. I repeat, the stock and short barrel must never be on the receiver at the same time or you will have created an illegal short barreled rifle (SBR).
The proper order for converting a rifle BACK to an AR pistol is to remove the stock, remove the 16″+ barrel, and finally install the <16″ barrel.
There is some wisdom in building every AR-15 lower receiver that you purchase into a pistol first. That way you have the maximum versatility should you want to convert it to a pistol later.
Cite: BATFE on converting pistols to rifles
Receiver Extensions
Speaking of removing and reinstalling the stock… One of the most widely spread gun-counter dogmas regarding AR pistols is that you must use a receiver extension (buffer tube) that cannot except a stock. People often cite “constructive intent” when discussing why you must use a receiver extension that can not accept a stock. They state that if you were to own both a stock and an AR pistol that could accept the stock, you could be cited for the intent to create an illegal SBR. This is not necessarily true.
Owning a buttstock is not illegal as long as you have a legal use for it. Installing it on an AR pistol to create an unregistered SBR is illegal. Owning a car that is capable of exceeding the speed limit is not illegal. Exceeding the speed limit is illegal.
In my opinion (for whatever it’s worth), a wise way to approach the situation is to say that if you only own an AR-15 pistol, don’t also own a buttstock. It will save you the temptation of installing it and prevent the appearance of illegal intent. If you own multiple other AR-15s that can legally accept a buttstock, feel free own as many buttstocks as you like. Just like if you own a legal SBR, you don’t have to register all your ARs as SBRs in order to own an upper with a short barrel.
“Constructive intent” is a boogeyman that has prevented a lot of people from doing perfectly legal things. Use common sense and follow the law as it is written. Using a standard receiver extension is legal and actually very handy if you plan on converting your AR pistol to rifle configuration as detailed above.
I do acknowledge that this is perhaps a gray area and even the cited letter below says that owning a stock with an AR pistol that can accept it “may” be breaking the law. So, without a doubt, the absolute safest way to go is with a receiver extension that cannot accept a stock.
Cite: BATFE on receiver extensions
Cite: More information here
Photo courtesy of HausofGuns.com
Pistol Lowers Must Be Marked as Pistol Lowers
There was a time when having a pistol marked lower receiver made some sense but it has never really mattered what the lower says. It has always mattered how it was transferred. It is a pistol if…
It was transferred as a pistol (receivers are no longer transferred as pistols).
It was transferred as a receiver and then built into a pistol first.
Vertical Grips and Similar
Installing a vertical grip on an AR pistol is illegal. It, by classification, creates an illegal Any Other Weapon (AOW). However, recent BATFE clarifications have created some options you should be aware of.
The BATFE has clarified that it does not consider angled foregrips like the Magpul AFG a vertical grip and therefor it is legal to install on an AR pistol.
Additionally, if the AR pistol has an overall length of 26″ or greater (the BATFE’s definition of not easily concealed) and lacks a buttstock (not an SBR), you may install a vertical grip because it does not fit the BATFE’s definition of a “handgun”. AR pistols in this configuration do not fit any BATFE definition and thus are classed generically as a “firearm”. Guns that are classified as “firearms” may have vertical fore grips installed. To be clear, in this case the term “firearm” is an actual BATFE classification of a gun that meets certain criteria not a general term used for all guns.
The overall length is measure from the tip of the bare muzzle (the muzzle device does not count unless it is permanently attached) to the back of the receiver extension.
It should be noted that if you are carrying an AR pistol legally by virtue of a concealed handgun license, adding the vertical grip makes it something other than a handgun.
Cite: Franklin Armory compiled info on vertical grips
Cite: BATFE on AFG
Cane Tips and Buffer Tube Bumpers
The BATFE has clarified that a rubber cane tip placed on the receiver extension (buffer tube) does not constitute a stock. This can make the AR pistol easier to stand up in a safe and protect the rear of receiver extension.
Cite: BATFE on cane tips
Shooting an AR Pistol Certain Ways is Illegal
Some people will tell you that shooting an AR pistol with the receiver extension against your shoulder is illegal because the receiver extension then becomes a shoulder stock. That is incorrect. The AR pistol is a pistol by virtue of the way it was transferred, initially built, and the fact that its features meet the definition of a pistol set forth by the BATFE. Its classification can not be changed by shooting it a certain way.
This would be like saying that a 1911 or Glock become illegal if they are shot while pressed against your body. Again, use common sense and follow the laws as written.
Due to a recent reversal to the ATF’s position on the Sig SB15 Brace and the legality of using it against the shooter’s shoulder, this section may no longer be up to date. I am awaiting further clarification.
Wrap Up
AR-15 pistols don’t have to be complicated. Just do a little research, follow the laws as written, and enjoy yourself. If you are looking for more information, check out Haus of Guns’ ongoing coverage of what he is learning from his recent AR-15 pistol build. You can also check out AR15News.com’s recent build for some inspiration. Both sites offer good insight into what makes these guns work.
http://jerkingthetrigger.co...some-misconceptions/
[This message has been edited by dennis_6 (edited 07-23-2017).]
jmbishop
Total ratings: 169
Report this Post07-23-2017 05:09 PM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've never been an AR guy. Mostly because they've been overpriced, until recently you've been paying for hype and honestly, while the design works, it's not that great. However now that the price finally reflects what your buying, I finally got into them. I built one exactly how I wanted it for $500. It's hard to beat building a rifle $50 at a time.
I don't care for AR pistols but if you don't want a tax stamp but want a short barrel, it's what you have to do. Like you said, it's more evidence the NFA needs to go and the ATF needs to be neutered and held accountable for is many blunders. Also, if you want to know how sick people at the ATF are, follow their Facebook so you can see their posts about naming their dogs after terrorist organizations.
You should look up Dimitri Karras o Facebook. He's challenged the ATF and won after being raided. A few thousand AR15 80% s where returned to him after he died the ATF, he was told not to sell them so he went to their headquarters and sold them in the parking lot lemonade stand style.
https://youtu.be/sv1s6qH6rBo
[This message has been edited by jmbishop (edited 07-23-2017).]
Hudini
Total ratings: 165
Report this Post07-23-2017 10:19 PM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 80% lower that I considered building into a pistol AR until I read about how if they are not built properly may lead to feed issues. An SBR with a suppressor though would rock. Unfortunately you are looking at $400 in Tax Stamps plus the gun cost plus the waiting time.
sardonyx247
Total ratings: 219
Report this Post07-24-2017 07:20 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
My freind has an AK pistol, he didn't have to jump through hoops, I love Nevada. So much fun to shoot.
And with his CCW he can conceal carry.
Btw, what a book to read above. Good info though.
E.Furgal
Total ratings: 278
Report this Post07-24-2017 08:26 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like the fed tax code...
jmbishop
Total ratings: 169
Report this Post07-24-2017 01:37 PM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the point of a AR pistol, no hoops to jump through.
dennis_6
Total ratings: 115
Report this Post07-25-2017 07:29 PM Click Here to See the Profile for dennis_6Send a Private Message to dennis_6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Till the atf reverses its position on the pistol brace or makes all but one model illegal to shoulder. Or you add a forward grip on a 26" oal pistol and they reverse that position.
jmbishop
Total ratings: 169
Report this Post07-25-2017 09:45 PM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
See comments about Dimitri Karras. They are in the wrong and they can be fought but not many people are willing to do what it takes, too many are willing to comply and let freedom die.
I'll admit I'm guilty, I comply 100% with the ATF because I live under the oppression because I fear what they would do to me my, family and my dog. I have no illusion of being a threeper but there is a line that would drive me to it.
[This message has been edited by jmbishop (edited 07-26-2017).]
dennis_6
Total ratings: 115
Report this Post07-25-2017 11:32 PM Click Here to See the Profile for dennis_6Send a Private Message to dennis_6Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'll admit I'm guilty, I comply 100% with the ATF because I live under the oppression because I fear what they would do to me my, family adds my dog. I have no illusion of being a threeper but there is a line that would drive me to it.
Like what happened to ken ballew.
jmbishop
Total ratings: 169
Report this Post07-26-2017 01:56 AM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Exactly and even though he lived, nobody held anyone accountable despite the victims best efforts.
Luckily we are living in different times where the individual is capable of generating media and putting social pressure on things like this case, unfortunately that social pressure can also be applied to things that aren't logical or legal.
Dimitri actually went viral before the ATF raid. He obtained a restraining order against and explained the ATF tried to extort customer info from him. The ATF continued with the raid anyway and luckily the store was closed and their were no shootings. Bystanders and protesters filmed it.
One of the hilarious events as a result of the case is that when Dimitri who has yet to be charged with anything sued to get his lowers back, the ATF told him they where still firearms. The ATF then shipped them back to Dimitri, thousands of them with a few missing, that's right, not a FFL, to Dimitri which would be a felony if they were actualy firearms. And the missing "firearms" no doubt taken home by some sticky fingered ATF agents or used in some type of fast and furious sting would be a big deal, something the ATF should really look into.
There are many people who won't get their day in court thanks to the ATF, Waco comes to mind but there are many more.
Don't read this one unless you're looking to elevate your blood pressure. http://jimbovard.com/blog/2...er-holding-her-baby/
dennis_6
Total ratings: 115
Report this Post07-26-2017 04:36 PM Click Here to See the Profile for dennis_6Send a Private Message to dennis_6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dimitri actually went viral before the ATF raid. He obtained a restraining order against and explained the ATF tried to extort customer info from him. The ATF continued with the raid anyway and luckily the store was closed and their where no shootings. Bystanders and protesters filmed it.
Well aware of ruby ridge and waco, waco2 also some of the more recent tyranical over reaches of the atf.
Missed the dimitri fiasco, but read into the other day. Man has balls of steel and a true patriot.
