  Totally O/T
  Spraying brake cleaner into engine - did I ruin my O2 sensor?
Spraying brake cleaner into engine - did I ruin my O2 sensor? by masospaghetti
Started on: 02-05-2017 10:48 PM
Replies: 12 (1315 views)
Last post by: E.Furgal on 02-06-2017 06:46 PM
masospaghetti
Report this Post02-05-2017 10:48 PM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I stupidly didn't do any research on this before I sprayed some chlorinated brake cleaner down into my engine cylinders in an attempt to decarbonize the piston and rings. I didn't have any carb cleaner on hand so I used the next closest thing. Apparently brake cleaner decomposes into phosgene gas when it burns. Luckily I didn't spray much down there.
Car ran really poorly for about 10 minutes but seems to be basically OK now. Did I just fry my O2 sensor?
I'm really worried because I actually have the regular O2 sensor and an additional wideband sensor installed, and those wideband sensors are not cheap!
It's on a Honda H23 engine if it matters.
Thanks
E.Furgal
Total ratings: 278
Report this Post02-05-2017 10:58 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
maybe,, there is a reason they have sensor safe sprays
WBailey1041
Total ratings: 81
Report this Post02-05-2017 11:06 PM Click Here to See the Profile for WBailey1041Send a Private Message to WBailey1041Edit/Delete MessageReply w/QuoteDirect Link to This Post
Lmao, explain the procedure, you could have also hit the MAF if you sprayed it in the intake near the air filter.
Stubby79
Total ratings: 58
Report this Post02-06-2017 02:00 AM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
spark1
Total ratings: 175
Report this Post02-06-2017 03:19 AM Click Here to See the Profile for spark1Send a Private Message to spark1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Guess you saw this: Brake Cleaner = Phosgene Gas
masospaghetti
Report this Post02-06-2017 07:29 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was dumb, I know.
I sprayed some cleaner directly down the spark plug holes and let it sit for awhile. Luckily no MAF on this car.
E.Furgal
Total ratings: 278
Report this Post02-06-2017 08:03 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why?? remove carbon??
running engine with it feed air with water mist is better at this than cleaning all oil off the rings and cyl wall.
masospaghetti
Report this Post02-06-2017 09:26 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have excessive crankcase pressure and wanted to rule out stuck/dirty rings. I let the engine crank over a good 15 seconds or so with the plugs removed so hopefully I didn't scuff the crap out of my cylinder walls.
Not one of my finest moments.
WBailey1041
Total ratings: 81
Report this Post02-06-2017 10:00 AM Click Here to See the Profile for WBailey1041Send a Private Message to WBailey1041Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'd bet you only fouled the plugs, clean them up, sand the electrodes lightly until bare metal is exposed. (I'm assuming you don't wanna spend the time or money on new plugs considering your history with the brake parts cleaner)
Reinstall and if throw a code for O2 sensors you just learned an expensive lesson.
Stubby79
Total ratings: 58
Report this Post02-06-2017 10:27 AM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's more or less how we used to do it. "Give it a drink"...tech would pull a small vacuum hose and let it suck in a cup of water slowly(note slowly...you don't want to hydro-lock the engine). I stuck with spraying a mist, as I didn't care to find out where the line is...
Haven't bothered in years...gas seems to be better these days around here. They almost all claim to have cleaner additives. I just go for a hard run up the mountain/highway if I feel the need to clean her out.
masospaghetti
Report this Post02-06-2017 11:48 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm really not that cheap, it was a matter of convienence and what I had on hand... I don't care about spending $10 on a set of plugs. I did it because i knew brake cleaner and carb cleaner both powerful solvents and dissolve carbon.
Anyway, lesson learned...it could have ended with a cloud of phosgene gas so I consider myself lucky
[This message has been edited by masospaghetti (edited 02-06-2017).]
WBailey1041
Total ratings: 81
Report this Post02-06-2017 12:05 PM Click Here to See the Profile for WBailey1041Send a Private Message to WBailey1041Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm really not that cheap, it was a matter of convienence shortcuts and what I had on hand... I don't care about spending $10 on a set of plugs. I did it because I DIDN'T KNOW ANY BETTER..
Anyway, lesson learned...it could have ended with ONLY WASTING A CAN OF CARB CLEANER INSTEAD OF A COUPLE OF O2 SENSORS.
Fixed that for you. ^^^^^
We have all done silly things, it's best to own up to it and move on. Forgive me if I took you for a penny pincher, most of us are always looking for a shortcut. Hopefully the plugs are the end of it.
[This message has been edited by WBailey1041 (edited 02-06-2017).]
E.Furgal
Total ratings: 278
Report this Post02-06-2017 06:46 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gas today has ethanol that collects moisture in the air..(water) that cleans out the carbon..
huge problem with direct injection engines is the carbon build up on valves back faces..
as no fuel is passing it to clean it.. only the burnt h/c from the valve overlap
