  Totally O/T
  Monitor settings, HP 1702 ?
Monitor settings, HP 1702 ? by MidEngineManiac
Started on: 02-03-2016 08:42 PM
Replies: 9 (195 views)
Last post by: Monkeyman on 02-04-2016 06:46 AM
Total ratings: 297
Report this Post02-03-2016 08:42 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
I picked up a good working BIG monitor today (not really by today's standards, but still a 17" flatscreen.) for a whopping 10 bucks ...but I am having a b*tch of a time to get it to display properly.
The computer driving it is an Acer Aspire One notebook, with a 12" wide screen. I am trying to get a desk set up so I just plug in 2 or 3 cords and use the Acer like a desktop, then grab-and-go when I need to. This HP monitor (17" SQUARE) is squeezing everything in on the sides, and stretching it out height-wise. Anybody know how to get the aspect ratio fixed ?
[This message has been edited by MidEngineManiac (edited 02-03-2016).]
Total ratings: 106
Report this Post02-03-2016 08:54 PM Click Here to See the Profile for williegoatClick Here to visit williegoat's HomePageSend a Private Message to williegoatEdit/Delete MessageReply w/QuoteDirect Link to This Post
It looks like that monitor wants 1024x768 (5:4). What do you have it set at?
Formula88
Total ratings: 554
Report this Post02-03-2016 08:57 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are you using an Operating System on your notebook?
You need to set the video resolution to whatever the native resolution of the 17" screen is. Until you get it displaying correctly, leave the laptop closed. Don't try to use multiple screens until you have 1 working right.
Total ratings: 436
Report this Post02-03-2016 09:20 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
How do you make any kind of input on a laptop with it closed?
Total ratings: 106
Report this Post02-03-2016 09:25 PM Click Here to See the Profile for williegoatClick Here to visit williegoat's HomePageSend a Private Message to williegoatEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMSA GT
Total ratings: 250
Report this Post02-03-2016 09:26 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most of the time laptops do strange things with the picture when both are in use. As mentioned above, close the laptop cover and see if that corrects the issue.
[This message has been edited by IMSA GT (edited 02-03-2016).]
Blacktree
Total ratings: 350
Report this Post02-03-2016 11:01 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can't do a multi-monitor setup on your laptop? I'm not very familiar with laptops, but on a desktop box you can select "extend my desktop to this monitor" in the graphics settings. That will use the second monitor as extra desktop space, instead of just a copy of the first. And once you have that option enabled, you should be able to select a different resolution for the other monitor, so it won't be squished and/or stretched.
[This message has been edited by Blacktree (edited 02-03-2016).]
Total ratings: 297
Report this Post02-04-2016 02:52 AM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cant close the cover, it goes to sleep and it doesn't seem capable of setting the 2 independently. Looks like the only option is to adjust the settings depending on which monitor I am using.
Stubby79
Total ratings: 58
Report this Post02-04-2016 03:33 AM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you're running Windows of any kind, go to "power settings" and look around. In there you can check off what the computer does when you close the lid.
There's usually a hot key for turning off the laptop screen and going to the other screen only. It's Fn + f8 on my computer, for example. Otherwise, you should be able to choose which screen to output to in the video card settings. You might be able to run both at once, at different resolutions, even.
Monkeyman
Total ratings: 180
Report this Post02-04-2016 06:46 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ran (2) 24" monitors off of my laptop for a while with Win7, an external trackball and keyboard the laptop closed. It can be done.
