  Totally O/T
  Shifted glass shower door...how to reset
Shifted glass shower door...how to reset by Hank is Here
Started on: 12-02-2015 09:16 PM
Replies: 7 (304 views)
Last post by: rogergarrison on 12-04-2015 11:15 AM
Hank is Here
Total ratings: 103
Report this Post12-02-2015 09:16 PM Click Here to See the Profile for Hank is HereSend a Private Message to Hank is HereEdit/Delete MessageReply w/QuoteDirect Link to This Post
We recently got a new, to us, house that has a hinged glass shower door. The door has is held into the hinge by compression. The problem is the door shifted from the top of the frame by about 1/4 inch which now prevents the door from closing fully. I want to be careful in what I do so I don't end up with a shattered door. And folks with experience?
Thunderstruck GT
Total ratings: 99
Report this Post12-02-2015 09:25 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kinky sex?
rogergarrison
Total ratings: 551
Report this Post12-03-2015 09:47 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might try using a heat gun or hair dryer to warm up the frame. It will soften any adhesive plus expand it slightly. Then just try pushing the glass back into it. If that works, put a small bead of waterproof silicone on the seam, on both sides, to keep it from pulling back out. If it wont go back in, take a chance using a bar clamp across the glass and over both sides (against some wood blocks to spread the load) and slowly draw the clamp together. The glass should be pretty strong if you pull it laying close to glass and your pulling 90* to face of the glass. wear some safety glasses. Worse that could happen is the glass breaks, but its not usable anyway right ? Lay down some paper or plastic in case it does so it will be easy to clean up.
[This message has been edited by rogergarrison (edited 12-03-2015).]
Total ratings: 297
Report this Post12-03-2015 10:23 AM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
3 pounds of C-4 should straighten it right up. Meh, better use 5 pounds just to be sure
Report this Post12-03-2015 11:59 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spot Heat can break the safety glass.
Tony Kania
Total ratings: 305
Report this Post12-03-2015 12:01 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Give me a pic. I can set you straight. A few others here are visual. A pic will solve your problem quickly.
Total ratings: 436
Report this Post12-03-2015 12:51 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Too many different shower door designs out there to give a solution without more info. I have one, where the frame has separated from the glass about 1/4" about 12 way down the hinge side, but it's because of settling in the floor which makes the door opening no longer square and plumb. (whole house is settling actually)
It's on my 'fix it' list, and will be an easy fix since the door frame has adjustment where the top hinge is affixed.
[This message has been edited by maryjane (edited 12-03-2015).]
rogergarrison
Total ratings: 551
Report this Post12-04-2015 11:15 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre:
[QUOTE]Originally posted by rogergarrison:
[/QUOTE]
I didnt mean hot enough to burn your hand. I meant 'warm' it up down the entire side. Could do the same thing if you took the door off and set it out in the sun for a few hours.
Ive watched how this type of door is made...they do RV windows the same way. They lay the glass flat on a plate, and press the metal sides onto it with a press that runs down the length of it. They use a hardening adhesive to bond the corners/ seams.
[This message has been edited by rogergarrison (edited 12-04-2015).]
