  Totally O/T
  What can cause a highway vibration besides wheels or tires?
What can cause a highway vibration besides wheels or tires? by masospaghetti
Started on: 08-07-2015 02:24 PM
Replies: 28 (614 views)
Last post by: masospaghetti on 08-12-2015 08:56 AM
masospaghetti
Report this Post08-07-2015 02:24 PM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just had the wheels and tires on my road force balanced by the dealership and everything is spot on. Still has a vibration in the steering wheel between 65-75 mph.
What else could possibly cause it? It does not change with acceleration or deceleration or with brake application.
It's a 93 Honda Accord.
Report this Post08-07-2015 03:04 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wheel bearing maybe? Is there some sort of shaft support bearing on those?
Brake dragging?
This is on smooth pavement right?
[This message has been edited by 2.5 (edited 08-07-2015).]
masospaghetti
Report this Post08-07-2015 03:08 PM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah smooth pavement. I had the tires balanced three times by NTB, then just to make sure I had the Honda dealer do the road force balancing, they also said the wheels are true and straight.
Would bad bearings cause a vibration? I figured they would just make a bunch of noise.
Total ratings: 297
Report this Post08-07-2015 03:25 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Steering dampner ?
Total ratings: 226
Report this Post08-07-2015 03:31 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only between 65 and 75? Sure sounds like a tire/wheel out of balance but in that you've had it checked several times, I guess we'll have to eliminate that.
Such a vibration is most likely coming from a rotating assembly but, there are other possibilities. Have you had your suspension checked for worn bushings? How about your engine/transmission mounts? Shocks/struts in good shape? Steering linkage? Hard to diagnose a problem without actually seeing/driving the vehicle but, if were me, I'd ask an experienced Honda Tech to take it for a test drive and get his/her opinion.
Ron
My Uncle Frank was a staunch Conservative and voted straight Republican until the day he died in Chicago. Since then he has voted Democrat. Shrug
[This message has been edited by blackrams (edited 08-07-2015).]
Report this Post08-07-2015 03:38 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
A flaw in a tire, worn suspension components like inner or outer tie rods, warped brake rotor, worn drive axle to name a few, but usually 35 and again around 65 indicates balance.
Total ratings: 398
Report this Post08-07-2015 03:58 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
warped brake rotor could also cause it to vibrate
masospaghetti
Report this Post08-07-2015 04:07 PM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would a warped rotor cause a vibration without braking?
Unfortunately the honda techs were not able to find anything wrong, they said the suspension looked really good.
Report this Post08-07-2015 04:17 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did it ever not have this vibration?
tebailey
Report this Post08-07-2015 04:43 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Although rare I have had a rotor out of balance enough to cause a vibration at 45.
Report this Post08-07-2015 04:43 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bent rim(s)?
rogergarrison
Total ratings: 551
Report this Post08-07-2015 05:00 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
axle CV joints bad ? If its a stick, clutch or pressure plate bad.I wouldnt suspect the steering damper (if it has one) as I always took them off and threw them away from Fieros to Mercedes. Broken belt in tire.
Do you have someone you can swap their tires and wheels onto yours to try. If not, try switching yours from front to rear and see if either has any effect. Even if theyre different sizes, it wont hurt for a short test run.
On hard to find vibrations, I like to take my cars to a local shop that spin balances them on the car. Anything out of wack on a wheel or tire will show up right away. Bubble or computer balance may be right on, but it dont show an out of round rim or tire. You need to run the wheel to speed and measure runnout with a gauge.
[This message has been edited by rogergarrison (edited 08-07-2015).]
Hudini
Total ratings: 165
Report this Post08-07-2015 08:08 PM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
I second the flaw in the tire. Check for a broken belt by slowly running your hand all around the tires feeling for a slight bulge. Years ago I had a Buick that vibrated at speed. I balanced the tires several times all to no avail. Finally a tech at one of the tire places showed me the bulge on 2 of my tires. Apparently the steel belts can break or shift and the tire will never run smooth. So I bit the bullet and bought a set of Michelins and enjoyed the smoothest set of tires I have ever felt. I was so impressed that I swore off all other brands.
FriendGregory
Report this Post08-07-2015 09:30 PM Click Here to See the Profile for FriendGregorySend a Private Message to FriendGregoryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Hudini:I second the flaw in the tire. Check for a broken belt by slowly running your hand all around the tires feeling for a slight bulge. Years ago I had a Buick that vibrated at speed. I balanced the tires several times all to no avail. Finally a tech at one of the tire places showed me the bulge on 2 of my tires. Apparently the steel belts can break or shift and the tire will never run smooth. So I bit the bullet and bought a set of Michelins and enjoyed the smoothest set of tires I have ever felt. I was so impressed that I swore off all other brands.
I will go third on the bad tire. I had one that looked fine, I rotated it to the back, the problem was barely noticeable so, I was going to ignore it. Al the sudden, a baseball sized deformity appeared on the tire and the car was undriveable.
Rotate or replace the tires.
Stubby79
Total ratings: 58
Report this Post08-07-2015 09:41 PM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree to try rotating the tires and see if it makes a difference.
Otherwise the only thing that comes to mind that I haven't seen mentioned is alignment issues.
Report this Post08-07-2015 09:56 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a modern car, but use some old school technology. If you feel it in the steering wheel, it's in the front. If you feel it in your butt, it's in the rear.
BlackEmrald
Report this Post08-07-2015 10:15 PM Click Here to See the Profile for BlackEmraldSend a Private Message to BlackEmraldEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bad tire, warped rotor or bent rim.
Most tire machines will only detect a bent rim if the machine is calibrated before balancing (often a skipped step) and if the bend is somewhat significant.
Complain until they give you a new set of tires so we can rule that out.
masospaghetti
Report this Post08-08-2015 08:25 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks everyone for the suggestions. I tried rotating the tires and the problem did not change. I'm beginning to think it might be a bad rotor, I would hope that all my of my tires aren't defective, they are a decent brand (Cooper CS5 Ultras).
Would this show up on a road force balancer? My impression was that a road force machine would pick any hard spots or irregularities in the wheel or tire.
Unfortunately replacing the rotors on this car requires removing the knuckle - stupid Honda captive rotors
[This message has been edited by masospaghetti (edited 08-08-2015).]
Report this Post08-08-2015 10:06 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can check runout on the rotors before pulling them. Just set up some kind of stationary pointer that you can touch against the friction surface of the rotor. Turn the rotor and if the pointer doesn't stay in contact, pull it and have it turned.
Stubby79
Total ratings: 58
Report this Post08-08-2015 11:10 AM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
If it was enough to cause vibrations, I'd think he'd be able to feel the brake pedal pulsing. Maybe not, but that would be my assumption.
BlackEmrald
Report this Post08-08-2015 11:28 AM Click Here to See the Profile for BlackEmraldSend a Private Message to BlackEmraldEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately, I don't have any direct experience with road force machines.
If you check the rotor runout and they are OK, I would suggest CV axle or bearing problems.
masospaghetti
Report this Post08-09-2015 10:12 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took apart the driver's side today and got the rotor off. Nothing obvious but I do remember that I had to grind on the rotor to get the hub to fit, apparently this is a really common problem. I'm going to install some "ultra premium" rotors that are supposedly mill balanced and hopefully don't have to be ground to fit.
I sure hope its not axle problems. They were super-expensive Raxles with new Lobro CV joints. That is a whole another story though. Driver's bearing feels nice and tight and smooth.
I have a suspicion that all of the "non-premium" rotors are made by the same company and from the same factory despite the dozen or so different brand labels. And probably, the "premium" rotors are all made by a second factory somewhere. I even thought about getting OEM Honda rotors from the dealer for $100 each
[This message has been edited by masospaghetti (edited 08-09-2015).]
rogergarrison
Total ratings: 551
Report this Post08-09-2015 08:21 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
an out of round rotor can vibrate when spinning and not cause the brake pedal to vibrate.
BlackEmrald
Report this Post08-09-2015 08:31 PM Click Here to See the Profile for BlackEmraldSend a Private Message to BlackEmraldEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let us know the result of changing the brakes. I'm very interested.
Report this Post08-09-2015 09:33 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Careful... Vibration may feel came from front but is really came from back or other way around.
Bent axles or dieing trans bearings can axle vibration. Dieing trans bearings can allow inner CV to rotate off center.
If You have spare set of mounted wheels or can borrow a set then do that. Another set will answer it is a tire problem.
Like cars w/ GA and other brake upgrades w/o hub centric rings/shims.
Total ratings: 226
Report this Post08-09-2015 10:04 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
You had to grind on the rotors to make them fit? Never heard of that before. Hmmm..................................
Ron
Report this Post08-10-2015 10:15 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can you shake the CV to diagnose trans bearings?
E.Furgal
Total ratings: 278
Report this Post08-10-2015 10:29 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
1) out of round tire
2) tire run out (tread)
3) motor mount/trans mount
4) loose subframe(cradle) bolts
5)engine balancer tossing a spot welded weight, same with flexplate/flywheel/torque converter/clutch
6) brake rotor tossing a balance weight .
7)control arm bushing shot..
8) missing lug nut
9) axle shaft balance weight tossed..
10) trans axle bearing shot..having play
11) axle shaft nut loose, most times from a shop reusing the old nut..
12) tire tech furbard the balance job.
13)upper strut bearing/plate shot or loose..
[This message has been edited by E.Furgal (edited 08-10-2015).]
masospaghetti
Report this Post08-12-2015 08:56 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not holding my breath but the drive this morning felt a lot better than before. Highway here isn't completely smooth so its hard to tell.
Replaced both brake rotors with NAPA/Raybestos "ultra-premium" rotors. I couldn't detect any warpage or out of round problems in the old ones but replaced them anyway. Honda's rotor design in the early 90's was terrible and requires removing the axle nut and separating the spindle from the LCA.
