  Totally O/T
  General A/C question - How to tell how much oil is in the system
General A/C question - How to tell how much oil is in the system by masospaghetti
Started on: 02-13-2015 09:56 AM
Replies: 6 (151 views)
Last post by: Imnuts on 02-13-2015 06:31 PM
masospaghetti
Report this Post02-13-2015 09:56 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
In general, in an automotive A/C system - is there any way to determine the oil quantity?
For example:
If you buy a Fiero with an inop A/C system, find that the high pressure switch was leaking and replace it, and recharge the system - How to tell how much oil needs to be added? Any "rules of thumb"?
Imnuts
Report this Post02-13-2015 10:07 AM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
You don't know. If the leak was very slow and had very little oil at the site most of the time you can just recharge the system. The best thing is to take it lose at the compressor, blow the system out with nitrogen, then pull vacuum and recharge with the proper amount of refrigerant and oil. If you are replacing the compressor make sure to have it converted over to 134A.
Hudini
Total ratings: 165
Report this Post02-13-2015 11:14 AM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the compressor starts making this god-awful shrieking noise then you do not have enough. Don't ask how I know this.
Total ratings: 441
Report this Post02-13-2015 11:40 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your's made a warning noise?
Mine always just very quietly but suddenly slipped into the dark jaws of compressor death.
masospaghetti
Report this Post02-13-2015 01:50 PM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmm, okay. I figured it wasn't possible to tell, thought it was worth a shot though. Compressor is nice and quiet for the time being.
I assume that too much oil (within a few ounces at least) doesn't hurt anything? I understand it will reduce the cooling capacity of the system since its basically displacing refrigerant.
Tony Kania
Total ratings: 305
Report this Post02-13-2015 02:00 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by masospaghetti:
... Any "rules of thumb"?
"The hits just keep coming!"
Imnuts
Report this Post02-13-2015 06:31 PM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most likely ok, don't have to tell you oil can't be compressed.
