Does the "tub" move around enough to be worried about flex.. ?
not knowing where this is in the tub, Hint a photo would help/
If it is 1/2 and round, Electrical boxes, and parts, have 1/2 round plugs you pop out to run romex, boxes are most times blue and gray, and some outdoor use are black..(if you choose to prep like listed below the plug color won't matter)
fit to hole, and plastic weld(you can get by with a solder gun) from the back side that you don't see, add a little plastic filler, to the top side, sand smooth, and then paint the tub with SEM plastic interior paint..
the paint won't flake off if you clean the tub and prime it, with their primer.. both are at most local parts stores..
http://www.tcpglobal.com/au...ydepot/semindex.aspxor go to a craft store and get a hole plug, used for piggy banks/etc.. packages here come with 5 different sizes, an auto parts store would also have grommet plugs.
maybe this will help..
[This message has been edited by E.Furgal (edited 02-09-2015).]
