  Totally O/T
  Will a clutch ever "chatter" when its fully engaged?
Will a clutch ever "chatter" when its fully engaged? by masospaghetti
Started on: 11-20-2014 02:11 PM
Replies: 11 (311 views)
Last post by: Stubby79 on 11-21-2014 11:10 AM
masospaghetti
Report this Post11-20-2014 02:11 PM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've felt warped flywheels before and they typically chatter during clutch engagement.
I'm getting a chattering feeling but when the clutch is fully engaged and when the drivetrain is loaded up (heavy acceleration). Happens in all gears. Could be described also as a shimmy, vibration, or wobble. It's a 93 Accord, but it's a fairly general question. Have you ever had clutch chatter like this before? Or do you think its something else?
I feel it in the steering wheel AND in the floor.
I just put new tires on it, made no difference, and have used two different brands of CV axles - no difference. One was Autozone, the other was a local rebuilder. 3 engine mounts were replaced, fourth was inspected good. All front end suspension parts have been replaced too.
Thoughts or opinions? This car is killing my wallet. I'm trying to determine if I have to drop the trans again - or pay someone to do it, since its a completely miserable job.
Marvin McInnis
Total ratings: 227
Report this Post11-20-2014 02:19 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any way to check/examine the hub and springs in the clutch disc? My guess would be that something's cracked, broken, or missing there.
Have you checked the condition of your motor/transmission mounts and the torque strut (i.e. dog bone)? Certainly worth checking before you split the engine and transmission.
[This message has been edited by Marvin McInnis (edited 11-20-2014).]
cliffw
Total ratings: 292
Report this Post11-20-2014 02:44 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, you haven't. How could a warped flywheel chatter. It is solid metal.
That sounds like work.
Which will need to be done anyway.
masospaghetti
Report this Post11-20-2014 03:10 PM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
A warped flywheel causes chattering of the clutch...my bad. The flywheel itself doesn't chatter.
gtjoe
Report this Post11-20-2014 06:22 PM Click Here to See the Profile for gtjoeSend a Private Message to gtjoeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had this happen once, and discovered during disasembly that the flywheel was not too far from escaping its perch on the crankshaft. several bolts were missing and the remaining ones were no longer tight
Total ratings: 436
Report this Post11-20-2014 07:46 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had it happen too /\
I have had a clutch chatter as well (fully engaged) if it was heavily glazed.
cliffw
Total ratings: 292
Report this Post11-20-2014 08:18 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Perhaps, likely. Think. How did your flywheel all of a sudden get warped ? It didn't.
It shouldn't.
What kind of vehicle ?
Hydraulic clutch ? Low on blinker fluid clutch master cylinder hydraulic oil ?
Is the (mechanical) clutch adjustable ?
Stubby79
Total ratings: 58
Report this Post11-20-2014 09:56 PM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
Unless it's slipping, I don't see a fully engaged clutch making any vibrations.
Maybe something else causing vibrations that simply remind you of it. I'd probably first consider something causing a misfire and or improper timing (valve or ignition). Maybe even an EGR or vacuum problem.
masospaghetti
Report this Post11-21-2014 09:13 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
It shouldn't.
Its a new flywheel, although the old one also did it.
I tend to agree with you - I have never experienced a bad clutch or flywheel causing vibrations when fully engaged but it was suggested to me by two separate mechanics. It's a 93 Honda accord, hydraulic clutch, new master and slave cylinders, plenty of fluid in there (just checked).
[This message has been edited by masospaghetti (edited 11-21-2014).]
masospaghetti
Report this Post11-21-2014 09:15 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
masospaghetti
Member since Dec 2009
That was my gut feeling too, just trying to rule things out.
masospaghetti
Report this Post11-21-2014 09:16 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
masospaghetti
Interesting, so it really can happen.
I sure hope my flywheel isn't about to come loose, that would cause some serious mayhem in that bellhousing
Stubby79
Total ratings: 58
Report this Post11-21-2014 11:10 AM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hmm...if any gears in the transmission (probably on the diff) had sheered off, you might only feel it skipping under heavy load. Can't remember exactly what it sounded or felt like, haven't seen it in a while.
