  Totally O/T
  Truth Or Dare: How To Make Coca Cola
Truth Or Dare: How To Make Coca Cola by Boondawg
Started on: 09-30-2014 12:55 PM
Replies: 5 (201 views)
Last post by: Formula88 on 09-30-2014 03:32 PM
Boondawg
Total ratings: 342
Report this Post09-30-2014 12:55 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
1. Mix 2,400 grams of sugar with just enough water to dissolve (high-fructose corn syrup may be substituted for half the sugar).
2. Add 37 grams of caramel, 3.1 grams of caffeine, and 11 grams of phosphoric acid.
3. Extract the cocaine from 1.1 grams of coca leaf (Truxillo growth of coca preferred) with toluol; dry the cocaine extract.
4. Soak the coca leaves and kola nuts (both finely powdered; 0.37 gram of kola nuts) in 22 grams of 20 percent alcohol.
5. California white wine fortified to 20 percent strength was used as the soaking solution circa 1909, but Coca-Cola may have switched to a simple water/alcohol mixture.
6. After soaking, discard the coca and kola and add the liquid to the syrup.
7. Add 30 grams of lime juice (a former ingredient, evidently, that Coca-Cola now denies) or a substitute such as a water solution of citric acid and sodium citrate at lime-juice strength.
8. Mix together 0.88 gram of lemon oil, 0.47 gram of orange oil, 0.20 gram of cassia (Chinese cinnamon) oil. 0.07 gram of nutmeg oil, and, if desired, traces of coriander, lavender, and neroli oils, and add to 4.9 grams of 95 percent alcohol.
9. Shake.
10. Add 2.7 grams of water to the alcohol/oil mixture and let stand for twenty-four hours at about 60 °F (15.5 °C). A cloudy layer will separate.
11. Take off the clear part of the liquid only and add the syrup.
12. Add 19 grams of glycerine (from vegetable source, not hog fat, so the drink can be sold to Jews and Muslims who observe their respective religion’s dietary restrictions) and 1.5 grams of vanilla extract.
13. Add water (treated with chlorine) to make 1 gallon of syrup.
Report this Post09-30-2014 01:56 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have indeed heard the original formula of Coke had cocaine in it.
Total ratings: 436
Report this Post09-30-2014 03:00 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
cocaine---for a nickel.
Khw
Total ratings: 134
Report this Post09-30-2014 03:10 PM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
And umm... What do they do with the byproduct from this step?
pokeyfiero
Total ratings: 309
Report this Post09-30-2014 03:16 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want a Coke
Formula88
Total ratings: 554
Report this Post09-30-2014 03:32 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
