  Totally O/T
  Aesthetically Speaking....
Aesthetically Speaking.... by whadeduck
Started on: 09-03-2014 08:47 AM
Replies: 9 (192 views)
Last post by: tshark on 09-03-2014 01:57 PM
whadeduck
Total ratings: 103
Report this Post09-03-2014 08:47 AM Click Here to See the Profile for whadeduckSend a Private Message to whadeduckEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I install flooring in my house using planks, is it better to run them across the back of the house or lengthwise? The main room (living room) is wider than it is long and has a vaulted ceiling if that helps any.
Whade' "Darkwing" Duck
Fieroless (11/18/12)
jaskispyder
Total ratings: 205
Report this Post09-03-2014 09:24 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Diagonal!
I would run the boards so they are running with the longest direction, but that is me, as that is what I did in my house with vinyl planks (sub-level room, so didn't want wood on the floor).
whadeduck
Total ratings: 103
Report this Post09-03-2014 09:30 AM Click Here to See the Profile for whadeduckSend a Private Message to whadeduckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know I'm either going to rent the house or sell it to someone who will rent it, so I'm going with vinyl planks for durability and ease of cleaning. I'll just have to buy enough of the material and then lay it out on the floor without gluing it down before I decide. But I want to run the pattern through the whole house aside from the kitchen and bathrooms.
jaskispyder
Total ratings: 205
Report this Post09-03-2014 09:42 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
BTW, I like the floating type of floor... vinyl. HD sells it as do others. Now they have the click together vinyl planks.
Total ratings: 436
Report this Post09-03-2014 10:02 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by jaskispyder:
Diagonal!
You may have been joking with that, but I have an old house on my property in which the original floor is done exactly like that--diagonally run true 1" oak floor planing.
jaskispyder
Total ratings: 205
Report this Post09-03-2014 10:11 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, some people do that. It is fine, but just more cutting of the product.
whadeduck
Total ratings: 103
Report this Post09-03-2014 10:37 AM Click Here to See the Profile for whadeduckSend a Private Message to whadeduckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, I'm going to stick to the K.I.S.S. principle on this one.
hnthomps
Total ratings: 50
Report this Post09-03-2014 11:44 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Richard,
Floating floors have their own issues as do vinyl planks. If you want more info give me a call or send a PM.
Nelson
FieroReinke
Report this Post09-03-2014 01:23 PM Click Here to See the Profile for FieroReinkeSend a Private Message to FieroReinkeEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should run it perpendicular to the longest length you will walk along. Reasoning is you will be less likely to see the joints. So if you have a long hallway, it should be installed the short way across the hallway not lengthwise down the hallway.
tshark
Report this Post09-03-2014 01:57 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
