  Totally O/T
  Bore sights, anybody use one ?
Bore sights, anybody use one ? by MidEngineManiac
Started on: 08-30-2014 03:39 PM
Replies: 7 (235 views)
Last post by: rogergarrison on 08-31-2014 11:01 AM
Total ratings: 297
Report this Post08-30-2014 03:39 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
I plan on swapping around some of my optics this weekend, and have been eyeing a boresight kit.....but before I go blow 60 bucks on one, I figgured I'd ask for experiences using them.
(its gonna be a fun setup.....red dot sight at 10 meters, under-muzzle laser 20. Split the difference for 15. )
........or I might blow the 60 bucks to go to the range instead, and just sight in the hard way.....maybee
[This message has been edited by MidEngineManiac (edited 08-30-2014).]
User00013170
Total ratings: 224
User on Probation
Report this Post08-30-2014 03:49 PM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
They work, i used one ( borrowed ) to sight in a laser and scope once.. With ammo being cheap it wasn't worth buying one.. These days it might well be worth it to save on wasted ammo.
WBailey1041
Total ratings: 81
Report this Post08-30-2014 07:26 PM Click Here to See the Profile for WBailey1041Send a Private Message to WBailey1041Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rickady88GT
Total ratings: 200
Report this Post08-30-2014 07:56 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
They are great. But you will need to get a three shot group dialed in afterwards. The laser gets you close fast.
jmbishop
Total ratings: 169
Report this Post08-30-2014 11:18 PM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
They work, it will get you on paper most of the time. I've had a chamber bore laser that the diode was not lined up perfectly but it still made it out the barrel and still got it on paper.
Total ratings: 297
Report this Post08-31-2014 02:46 AM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, after 5-hours of playing mix-and-match to get what I wanted (basically an update of my #1 barn/bat/pest rifle) and my "backup" set as close as I can (with the rails on it I am not going to get EXECTLY what I want without taking it to a machine shop to have some work done) I am DEFINATLEY getting one, a bore sight will save me HOURS of fracking around.
......and I learned something tonight. The Biathalon had the laser under the barrel on a ring mount. Scope (now a better scope) on top, thats a 2" differential at the muzzle between them (yeh, it was hell to set up 1st time around).....Just to see what would happen I loosed the screws and started rotating it, thinking I could get it within 10 degrees of vertical (close to the horizontal line on the scope) and was gonna leave it at the point it JUST started to show in the scope and work from there...
Well, it is now at 0 degrees, TDC, RIGHT on the centerline of the scope-----but doesnt obstruct the magnafied view in the slightest. I am thinking it is too close to the optics to be "picked up" in the scope--damned if I know why. I'll get a pic tomorrow, but there it is RIGHT in the line of sight and blocking nothing visually (while it completely obstructed the red dot sight)
I might just have to pick up another ring mount and put a tac light on this thing. Not like I dont have one after converting 2 others back to iron sights "just for fun shooting"
The entire reason for this exercise (and why I built this gun in its 1st incarnation in the 1st place 5 years ago) is rabbid bats have been found here AGAIN, and the new G/F has horses (yeah, go figgure how that worked out ) and with rabies around, with the way bats love barns........horses are seconds away from them and animal control is hours. or days.
Total ratings: 297
Report this Post08-31-2014 03:32 AM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Feb 2007
NM...double post.
[This message has been edited by MidEngineManiac (edited 08-31-2014).]
rogergarrison
Total ratings: 551
Report this Post08-31-2014 11:01 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I put a laser sight on my Highpoint, I just let the gunsmith mount and sight it for me....$15.00
