  Totally O/T
  Non Fiero question ( P. Sunfire)
Non Fiero question ( P. Sunfire) by LT188GT
Started on: 08-19-2014 07:19 PM
Replies: 5 (144 views)
Last post by: LT188GT on 08-20-2014 08:30 PM
LT188GT
Total ratings: 99
Report this Post08-19-2014 07:19 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
When replacing a I. A. C. valve on a 2004 Sunfire, is there a pre adjustment to be made like there is on a Fiero IAC?
Csjag
Report this Post08-19-2014 08:22 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would post this question in the "other makes" thread you will get a better response
squisher86SE
Report this Post08-20-2014 07:23 AM Click Here to See the Profile for squisher86SESend a Private Message to squisher86SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't think so, pretty sure it's just a simple R&R.
LT188GT
Total ratings: 99
Report this Post08-20-2014 03:43 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I went to the local Chevy dealer and he printed out the replacement procedure which states to match it up with the old one.
Install the replacement IAC.
Turn ON the ignition with the engine OFF.
Turn OFF the ignition for 10 seconds.
Start the engine and check for proper idle operation.
jimbolaya
Total ratings: 114
Report this Post08-20-2014 05:46 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Should be plug and play, but in case you want to check it, the distance from the mounting flange to the tip of the pintle should be no more than 1-1/8". Assuming this is the 2.2 ecotec, which I believe what was in all 04 Sunfire's and Cavalier's.
Jim
[This message has been edited by jimbolaya (edited 08-20-2014).]
LT188GT
Total ratings: 99
Report this Post08-20-2014 08:30 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Jim.
