  Totally O/T
  Kuerig maintainance tip
Kuerig maintainance tip by MidEngineManiac
Started on: 05-04-2014 09:46 AM
Replies: 5 (211 views)
Last post by: MidEngineManiac on 05-05-2014 02:44 PM
Total ratings: 297
Report this Post05-04-2014 09:46 AM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK guys here is an "idea from mom" that actually worked !!!!
I use the re-fillable cartridges most mornings (its a LOT cheaper than real k-cups, those are for a "special treat" only) but have been replacing them about every 3 months or so due to the micro-screens getting clogged up.
Ma gave me the idea to soak them in double-strength cleaning vinegar for about an hour then scrub them with a toothbrush. It worked like a charm. They came out like new, and the bowl of vinegar they soaked in got used for this months de-scalling runs.
Since I keep 6-9 of them around all the time, thats about $25 saved this morning, which means my next 12-pack is technically free !! (just go with the concept, OK )
Deabionni
Total ratings: 116
Report this Post05-04-2014 03:32 PM Click Here to See the Profile for DeabionniSend a Private Message to DeabionniEdit/Delete MessageReply w/QuoteDirect Link to This Post
We use the "MY K CUP" with our Kuerig, and haven't had any issues with the screen getting clogged or anything in the 1.5 years that we've been using it. Our cartridge came with our Kuerig, but the My K Cup can be found pretty easily from $8 to $15.
Total ratings: 297
Report this Post05-04-2014 03:56 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have one too, it has too much screen and not enough blockage for the strength I like. I tried the "cut a k-cup and insert it" modification, but it was still to weak for me.
With me, ESPECIALLY on those 3am mornings......if it dissolves the finish off the cup, its ALMOST strong enough.
These aftermarket things work pretty good with Melitta grounds.
[This message has been edited by MidEngineManiac (edited 05-04-2014).]
jaskispyder
Total ratings: 205
Report this Post05-05-2014 07:47 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have hard water? Are you running city or well water? What about putting the screen piece in some water to rinse it immediately after use?
[This message has been edited by jaskispyder (edited 05-05-2014).]
Fats
Total ratings: 75
Report this Post05-05-2014 01:46 PM Click Here to See the Profile for FatsSend a Private Message to FatsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've yet to have an issue with mine plugging up, but I'm only running bottled spring water through mine. I travel, tap water isn't an option most of the time.
Brad
Total ratings: 297
Report this Post05-05-2014 02:44 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Quite often I will make a "grab-and-go" cup when leaving the house, and those days the cartridge sits in the machine until I get home again then clean it. Thats probably whats doing it.
