  Totally O/T
  Gas Grill Maintenance
Gas Grill Maintenance by Lilchief
Started on: 04-29-2014 05:33 PM
Replies: 3 (148 views)
Last post by: cliffw on 04-30-2014 01:59 PM
Lilchief
Report this Post04-29-2014 05:33 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got some gas for my grill the other day and the grates are getting rusty. They were coated with black porcelain or something. What is causing the coating to come off ? Any way to stop this ? It's a brinkmann grill with cast iron grates.
85 GT 3.4
14.9 @ 90 1.9 60' Old TH125/3.06
Unknown New 4T60/3.42
tesmith66
Total ratings: 135
Report this Post04-30-2014 12:35 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
What is causing the coating to come off? Normal use. The only way to keep a gas grill from falling apart is to not use it. Well, that may just slow the process down a bit.
I have had MANY grills in my lifetime. I always buy middle of the road because no matter how much you spend, they will always need a complete overhaul every year or two.
Report this Post04-30-2014 01:12 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep I have to replace the grate every couple of years. Bring the grill out of the elements in for winter (unless you use it all winter then just cover it well). Alot of people dont even do that. Eventually the gas (plenums?) rust out.
I always thought it was dumb they make the outside nice shiney stainless and all the internals are not stainless.
[This message has been edited by 2.5 (edited 04-30-2014).]
cliffw
Total ratings: 292
Report this Post04-30-2014 01:59 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Meh ... the grill/grating on my wood fired pit rusts all the time when not in use often. I just burn it with a fire I start and then wire brush it. It has never hurt me.
Yeah, I have had gas pits with that coating. Ceramic ? I think many heating/cooling cycles help cause it, and once it starts it's like rust a grows/flakes off more.
I would replace it with some expanded metal.
