"86" Fiero S/C has blown head gasket how do I know, checked with a combustion leak tester probable cause installed smaller S/C pulley with stock head gasket probably should have installed a Fel-Pro MLS with smaller pulley. Car has new carpet, new upholstery, modified front fascia GT, Konig rims, 235/40ZR-17 tires bran new 400 miles on em, inverted front hood scoop, Transmission is FWD Getrag but I have an extra RWD Getrag with all shift brackets for a Fiero that will go with the car , instrument panel 120mph speedometer removed 85 mph panel, Awesome sound system, boost & fuel air ratio gauges I have all the parts emblems, badges etc, plus many extra parts I've been collecting for years even new OEM window dew strips, All wiring has NO BUTT splices all wires were soldered with heat shrink installed. Car is located 1 hour North West of Boise Idaho NO RUST I've been working on it for over 15 years & probably only put 400 miles on it since I started converting it, getting too old & need to devote my time to my 1948 Harley Davidson servi-car. Whoever buys will need to come pick it up it does run to drive on to a trailer but blown head gasket, If car doesn't sell by end of year i'll pull into my garage install head gasket & put on Craigs List.
Everything goes as a package will not sell separate, so don't ask. $7600
Car comes with extra 5 Speed RWD 282 Muncie Getrag, S/C pulley installation/ removal tool & all receipts and 3 ring binder 4 inches thick with schematics & articles explaining conversion & part numbers, many parts too many to mention relays, switches,
instrument panel
Car needs paint, head gasket , A/C plumbed & charged compressor is mounted on engine & wired up. final touches like installing conduit over wiring, Badges, installing sail panels etc.
