  The Mall
  Archie V8 master kit
Archie V8 master kit by jaybug56
Started on: 03-31-2025 02:33 PM
Replies: 2 (286 views)
Last post by: cartercarbaficionado on 04-02-2025 07:24 PM
jaybug56
Report this Post03-31-2025 02:33 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
V8 Archie master kit for sale
This kit is for a SBC. This includes the correct flex plate for the one piece rear main seal found on 1986 and newer small block Chevy.
This list is from v8archie.com
The Master Build Kit Includes All of the Parts Necessary to Perform a Fully Optioned V-8 Swap to Your Fiero.
Automatic Master Kit Includes:
 Engine/Trans. Adapter Plate
 Front Engine Mount
 A/C Mount
 Alternator Mount
 Torque Strut Rod
 Harmonic Balancer Pulley
 Custom Flex Plate Adapter
 Flex Plate 1985 & older SBC engines (see note below for newer engines)
 Fasteners Required
 Printed & Video Instructions
 Remote Oil Filter Kit
 Remote Oil Filter Adapter
 High Torque Starter
 High Performance Water Pump Drive System
 3-core Radiator
 Custom Exhaust System with Manifolds
Automatic Kit Price $2950.00
Note: The Flex Plate described above is for a 2 pc. Rear seal engine (1985 & older SBC engines). If you are using a 1 pc. Rear seal engine (1986 & newer SBC engines, the correct Flex Plate is $ 150.00 more.
Also Included Are All of the Correct Small Parts to Do the Conversion......
 Flex Plate Bolts
 Correct Flywheel
 Fuel Pump Block-off Plate
 Throttle Cable Mount
 Heater Hose Fitting 5/8"
 Heater Hose Fitting 3/4"
 Heater Hose 5/8"
 Heater Hose 3/4"
 Heater Hose Clamps
 4) Fuel Pressure Regulator
 Oil Filter Ph8a
 Fuel Line Clamps (4)
 Vacuum Hoses
 Radiator Hoses (6)
 Radiator Hose Clamps (12)
 90 Deg. Oil Filter Fittings
 All pipe fittings
 Fan Belt
and More....
I have dreamed of doing a V8 Fiero for years. More from an engineering standpoint, to prove my mechanical skills. It was fun to do and I learned a few things along the way. Mostly that it is more involved than people think.
So, a new kit is $2950 plus $150 for the flexplate. Plus hundreds more in other items that come up.
Bottom line is I need to get my money out of this so that I can start the next project. I completed it 4 or 5 years ago. It was fun. My urge for a V8 Fiero has been fixed. I've tried to sell the complete car several times unsuccessfully. People always with lowball offers that are more than insulting.
Selling now for $3500 A rust free 1986 Fiero GT 4spd automatic NO MOTOR but is ready to drop in your 1986 or newer SBC
FieroG97J
Report this Post04-02-2025 02:24 PM Click Here to See the Profile for FieroG97JSend a Private Message to FieroG97JEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is V-8 Archie still in business?
Report this Post04-02-2025 07:24 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes? sorta? i installed a kit for someone in jet city fieros (i hate mini starters.) and they called him with questions but i believe he doesnt do kits anymore or im just not around people who order them new
[This message has been edited by cartercarbaficionado (edited 04-02-2025).]
