  The Mall
  Overhead console lights
Overhead console lights by mrjay47
Started on: 02-24-2025 03:58 PM
Replies: 4 (93 views)
Last post by: Vintage-Nut on 02-28-2025 09:05 AM
mrjay47
Report this Post02-24-2025 03:58 PM Click Here to See the Profile for mrjay47Send a Private Message to mrjay47Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi. I am just changing the headliner with a Fiero Store product. I am putting in the new healiner and changed the bulbs in the overhead lighting console. I plugged them back in to test and nothing. Checked plug and there is 12+ volts there. Took the part to the bench and enrgized with a power probe. Powering the plug/connector I can get the courtesy center lights to turn on, but no power to the map lamps. If I power the small black wires going into the map light switches, it will light them. Plug the whole thing back into the car harness and nothing. I am at a loss right now. Any ideas would be much appreciated.
Rich
1985 Fiero GT
Report this Post02-24-2025 06:07 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rich
The ground for these are through the mounting bolts into the roof, from what I remember, without those grounded, nothing will work, at least not correctly.
da.slyboy
Report this Post02-27-2025 01:20 PM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is correct. I helped a gentleman with the same issue. Sometimes the screw mount can get a little corroded and the ground won't pass through (really only grounding through a thin contact patch of sheet metal) so you can screw the screw in/out a couple times to create a better contact patch.
mrjay47
Report this Post02-27-2025 05:54 PM Click Here to See the Profile for mrjay47Send a Private Message to mrjay47Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the answers. The problem ended up being that the led lights would not work with the car. Once I put the old incandescent bulbs back in and everthing was again right in the world. I could get the bulbs to light with my power probe, but not attached to the car power supply. I even chassis ground the area that you both mentioned and it failed to work also with the LED's. Now I just need to finish putting in the headliner. That's going slowly trying to match up the screw holes. Thanks for your help.
Rich
Vintage-Nut
Report this Post02-28-2025 09:05 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI
Incandescent bulbs are Non-Polarized
LED bulbs are Polarized
