  The Mall
  86 GT Part-out
86 GT Part-out by Cheeze_87
Started on: 04-01-2023 08:49 PM
Replies: 36 (1067 views)
Last post by: flimbob on 10-02-2023 08:50 AM
Cheeze_87
Report this Post04-01-2023 08:49 PM Click Here to See the Profile for Cheeze_87Send a Private Message to Cheeze_87Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you see something you want let me know. Willing to take anything off or apart. Chassis was hit drivers side and someone poorly grafted on a new front end. I have a few other Fiero parts laying around off camera. Or make an offer for all this stuff. Didn't get the title unfortunately, just wanted the body and didn't realize there was a mostly clean back half underneath it! Shame to send it to the scrapper with so many rust buckets like mine still in the road.
[img]https://images.fiero.nl/us erimages/Cheeze_87/20230401_135503.jpg[/img][img]https://images.fiero.nl/userimages/Cheeze_87/20230401_135 603.jpg[/img][img]https://image s.fiero.nl/userimages/Cheeze_87/20230401_135642.jpg[/img][img]https://images.fiero.nl/userimages/Cheeze_87 /20230401_135725.jpg[/img][img] [img]https://images.fiero.nl/userima" TARGET=_blank>https://images.fiero.nl/use...ges.fiero.nl/userima ges/Cheeze_87/20230401_141809.jpg[/img][img]https://images.fiero.nl/userimages/Cheeze_87/20230329_192509.j pg[/img]
MaxxPower1968
Report this Post04-03-2023 02:34 PM Click Here to See the Profile for MaxxPower1968Send a Private Message to MaxxPower1968Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have the driver side carpet trim that goes over the hand brake lever?
Cheeze_87
Report this Post04-03-2023 07:15 PM Click Here to See the Profile for Cheeze_87Send a Private Message to Cheeze_87Edit/Delete MessageReply w/QuoteDirect Link to This Post
This?
Fiero 86GT V6
Report this Post04-06-2023 08:08 AM Click Here to See the Profile for Fiero 86GT V6Send a Private Message to Fiero 86GT V6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi there,
I'm looking for a working fuel sending unit, with the float attached, for an 86 gt v6. The fiero store has one but it was too long by a few inches is causing problems. Also looking to buy the center console armrest if it's undamaged. If the radio area went unmodified and undamaged I am looking for the plastic face plate piece that fits over the radio and a/c controls.
[This message has been edited by Fiero 86GT V6 (edited 04-06-2023).]
MaxxPower1968
Report this Post04-06-2023 09:42 AM Click Here to See the Profile for MaxxPower1968Send a Private Message to MaxxPower1968Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Cheeze_87:
This?
I'm looking for the plastic cover. Mine is cracked and missing a few chunks.
It looks like this
MulletproofMonk
Total ratings: 78
Report this Post04-06-2023 02:05 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh Lord. I just scrapped that Fiero you brought down to me in 2020. The neighbors loved that.
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
MulletproofMonk
Total ratings: 78
Report this Post04-06-2023 02:14 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
MulletproofMonk
Member since Oct 2005
double
[This message has been edited by MulletproofMonk (edited 04-06-2023).]
Trinten
Report this Post04-06-2023 10:09 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have the A/C hose section that holds the orifice tube?
Does it look like it's in good shape?
If so, does $15 plus USPS flat rate small box shipping work for you?
Fiero 86GT V6
Report this Post04-10-2023 02:31 PM Click Here to See the Profile for Fiero 86GT V6Send a Private Message to Fiero 86GT V6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just checking in, haven't heard back from OP and wanted to see if the fiero parts were still there.
Cheeze_87
Report this Post04-12-2023 02:11 PM Click Here to See the Profile for Cheeze_87Send a Private Message to Cheeze_87Edit/Delete MessageReply w/QuoteDirect Link to This Post
It looks like this
This one cleaned up pretty well. Made sure it is not cracked or warped. $10 + shipping? I have more trim and interior parts if you want a deal on stuff. Trying to make it worth the shipping for ya, whatever that is going to be. Have a preferred shipper?
Cheeze_87
Report this Post04-12-2023 02:49 PM Click Here to See the Profile for Cheeze_87Send a Private Message to Cheeze_87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cheeze_87
Member since Oct 2009
Can't say I'm an AC expert. Which hose section holds the orifice tube? This is what this car looks like:
Cheeze_87
Report this Post04-12-2023 02:56 PM Click Here to See the Profile for Cheeze_87Send a Private Message to Cheeze_87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cheeze_87
Originally posted by Fiero 86GT V6:
Hi there,
I would say this unit does NOT work. It's pretty crusty. The tubes may be correct length but I'd say it needs a new pump and float and resistor.
Center console is warped and the color of the armrest postion looks a little lighter than the box area. No rips anywhere. I can clean it up to see if there is any other discoloration if you are interested still.
And unfortunately the radio bezel is cracked like most of them. Still have the little corner piece if you want to try and glue it up. I might just do that myself because it's in better shape than the one in my car!
Cheeze_87
Report this Post04-12-2023 03:03 PM Click Here to See the Profile for Cheeze_87Send a Private Message to Cheeze_87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cheeze_87
Bwahahahaha. Can I interest you in the same deal again? 😆 It's already on the trailer.
Fiero 86GT V6
Report this Post04-12-2023 05:32 PM Click Here to See the Profile for Fiero 86GT V6Send a Private Message to Fiero 86GT V6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here is my fuel sending unit, it doesn't look as crusty. Do you think this can be salvaged? If so do you have any tips? I have a friend that can work on the car but he's good but not a fiero guy.
Here's my center console where the rip is, It's got a little of the typical warping I've seen on videos. How does it compare to yours? If you think yours can clean up I'll take it.
Lastly here is my bezel, please excuse the 2000s cd player. I still have the original radio. This one is cracked in 2 places, the right crack looks identical to yours but I'll take yours please. One less crack is till an upgrade.
MulletproofMonk
Total ratings: 78
Report this Post04-13-2023 08:51 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Negative sir! BUT I will PM you a guys name that drove down from Saginaw to get parts. He is trying to fix up a 4cyl to save gas.
-Brian
MaxxPower1968
Report this Post04-13-2023 10:11 AM Click Here to See the Profile for MaxxPower1968Send a Private Message to MaxxPower1968Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes!! I'll definitely take it.
I could also use a lower seat cover if you're willing to remove it.
MaxxPower1968
Report this Post04-13-2023 10:20 AM Click Here to See the Profile for MaxxPower1968Send a Private Message to MaxxPower1968Edit/Delete MessageReply w/QuoteDirect Link to This Post
MaxxPower1968
Member since Jul 2022
PM sent
Cheeze_87
Report this Post04-14-2023 08:53 AM Click Here to See the Profile for Cheeze_87Send a Private Message to Cheeze_87Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would rather try to salvage that unit than use the one I have. I would buy a brand new fuel pump for it from Rock Auto (I'd get a Bosch or Delphi for this car and nothing else). Don't forget a new sump screen with it, they are usually sold separately for some reason. I would check to make sure the fuel level resistor works on your unit, I'm guessing it does as you are in California. Then I would find a way to check and make sure the float still works from my unit or obtain a better float from another parts car. I haven't even seen how they attach but thats what I would be looking to do if it were my nice car. I actually don't even run a fuel level sensor on my daily Fiero. I just go by mileage and reset the odometer when I fill up.
As far as the center console I'm not sure how much better mine it. There was some tape stuck to the top it looks like and the color is coming off in a few areas. I tried to take pics of all those areas. Cleaned up ok other than that. I'll let you decide if you still want it. Sorry I'm out of town until the week of April 23rd. I can get you a shipping quote when I'm back for anything you'd like.
Fiero 86GT V6
Report this Post04-14-2023 07:01 PM Click Here to See the Profile for Fiero 86GT V6Send a Private Message to Fiero 86GT V6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Please send a quote when you get back, I'll take the 3 parts and see if I can work with them. The forum email link points to a good working email. Thank you!
ReptilianRascal
Report this Post04-27-2023 03:45 AM Click Here to See the Profile for ReptilianRascalSend a Private Message to ReptilianRascalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi. I'm after some replacement seatbelt bolts for my 88GT. I'm in Australia and we have pretty strict rules here for seatbelts, so I basically have to have original bolts and the ones I took out if my car were quite stripped from a previous owner cross threading and over torquing them.
I'm after the buckle, B pillar and floor bolts.
Would you still have those bolts? Are they in good condition? Would you be willing to ship to Australia?
If you also have the barrels that go over the bolts to space the floor anchor, B pillar anchor and the buckle I would love those too.
Dukesterpro
Report this Post04-27-2023 09:28 AM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
How you much for parking brake handle + associated cables. I like everything from the handle to the caliper. Id also like to buy your tilt column if its in good shape? Im in Wisconsin
Fiero 86GT V6
Report this Post05-12-2023 08:24 PM Click Here to See the Profile for Fiero 86GT V6Send a Private Message to Fiero 86GT V6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any update on the quote? I've been checking my email inbox and the one here on the forums daily.
hnthomps
Total ratings: 51
Report this Post05-13-2023 05:00 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you happen to have the horn pin, spring, and plastic retainer? If so what is the price shipped to 29212?
Nelson
tomsablon
Report this Post05-21-2023 03:00 PM Click Here to See the Profile for tomsablonSend a Private Message to tomsablonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would you happen to have Front Side Marker Amber Lens 88 gt Right Hand ?
tomsablon
Report this Post05-21-2023 03:10 PM Click Here to See the Profile for tomsablonSend a Private Message to tomsablonEdit/Delete MessageReply w/QuoteDirect Link to This Post
tomsablon
Member since Feb 2009
MidWilly
Report this Post05-23-2023 12:33 PM Click Here to See the Profile for MidWillySend a Private Message to MidWillyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello, could you let me know if you have both front lower control arms and how much to ship to Canada Post code T0M0N0?
pHoOl
Report this Post05-23-2023 10:39 PM Click Here to See the Profile for pHoOlClick Here to visit pHoOl's HomePageSend a Private Message to pHoOlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm in search of the dash speaker covers, and some of the plastic A pillar retainer clips if you've got em available. I'd be a local pickup, no need to mess with shipping. Though as jacked up as all the freeways are around us, the Pony Express might be faster
Trinten
Report this Post05-24-2023 11:41 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
I apologize I missed your reply in this thread.
The AC Orifice tube section is located just under the fan, between the condenser and evaporator (picture courtesy of RWDPLZ). It's orientated horizontally.
Here's a pic of it in it's relative position, but with all the other AC things removed
Here's what it looks like when it's uninstalled:
Please let me know (and I'll double check to make sure I'm subscribed to the thread)
johnyrottin
Total ratings: 85
Report this Post05-31-2023 08:23 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a strange request. The PO of mine cut the radio plug out and wired an aftermarket stereo in. Nothing was soldered. They lost the plug along the way. Could you cut the harness plug out with as much wire as possible? I’d like to solder the harness plug back in to mine so I can do the Monsoon swap with plugs rather than Permian at install. This way I can go back to the original radio as well.
Options options options!
PM me.
John
rglasco101
Report this Post05-31-2023 12:29 PM Click Here to See the Profile for rglasco101Send a Private Message to rglasco101Edit/Delete MessageReply w/QuoteDirect Link to This Post
do you happen to have this guage?
what other interior trim parts do you have? mainly looking for the a-pillar trim parts
rglasco101
Report this Post05-31-2023 12:41 PM Click Here to See the Profile for rglasco101Send a Private Message to rglasco101Edit/Delete MessageReply w/QuoteDirect Link to This Post
rglasco101
Member since May 2022
also looking for these
Greentruck
Report this Post06-28-2023 08:41 PM Click Here to See the Profile for GreentruckSend a Private Message to GreentruckEdit/Delete MessageReply w/QuoteDirect Link to This Post
How's the engine cradle?
fredtoast
Report this Post06-29-2023 09:29 PM Click Here to See the Profile for fredtoastSend a Private Message to fredtoastEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have been here less than a month, so this is the first time I saw this thread.
I was so excited until I saw the final post.
Damn you, Greentruck!
Jerb
Report this Post09-19-2023 01:47 PM Click Here to See the Profile for JerbSend a Private Message to JerbEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the car is still around for parts
I'm interested in:
Battery tray
Gas filler neck/vent tube that goes from gashole to tank
I'm in Indiana 46227
Jerb
Report this Post09-19-2023 01:49 PM Click Here to See the Profile for JerbSend a Private Message to JerbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jerb
Member since Feb 2020
I'm interested in:
Battery tray
nosrac
Total ratings: 51
Report this Post09-30-2023 09:44 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM Sent
flimbob
Report this Post10-02-2023 08:50 AM Click Here to See the Profile for flimbobSend a Private Message to flimbobEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent
