  The Mall
  WTS Fiero Part Lot/Part Out New/Used Parts 38k Miles
WTS Fiero Part Lot/Part Out New/Used Parts 38k Miles by Robodog_X920
Started on: 06-10-2022 12:36 PM
Replies: 15 (821 views)
Last post by: Robodog_X920 on 12-06-2022 04:25 AM
Robodog_X920
Report this Post06-10-2022 12:36 PM Click Here to See the Profile for Robodog_X920Send a Private Message to Robodog_X920Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello all! Currently parting out a 1986 Fiero SE located in Grand Rapids, MI. I am getting as much off as I can, and will sell local or ship with additional fees. The original parts all clocked 38,709.8 miles when parked. Some parts were replaced and have about 100 miles total, some are in box new. I will put a list of what I have below, and edit it as need be. Additional pictures can be sent on request, a phone number will be included for text, but do NOT call me. I do not answer the phone, and it will go to an anti-scammer voicemail that is very unpleasant, and I don't want any of you to lose your hearing. I will include condition notes per part too.
Lot pictures at bottom of post
NEW PARTS
1X Hand Brake Cable Set FULL REPLACE (In Bag, All Hardware Unopened)
1X Spark Plug Wires STI Performance (New In Box Opened Unused)
1X 6x Spark Plug Set Copper (New In Box Open/Unopened Unused)
1X EGR Valve V6 (New In Box Open Unused)
1X EGR Tube (No Box, Unused)
1X Ignition Coil (No Box, Unused)
1X Fuel Pressure Regulator (In Box, Unopened Unused)
1X Battery Hold Downs (In Box, Unopened)
1X Temperature Sensor (No box, Unused)
1X Complete Vac Line Metal Replacements (In Box, Opened, Unused)
1X Intake Gasket Set(No Box, Unused)
USED PARTS UNINSTALLED
1X Driver Seat (Missing Handle Shield, Track Rust, Needs Wash, No Tearing, Original)
1X Passenger Seat (Some Track Rust, Needs Wash, No Tearing, Original)
1X Dashboard (potential crack near passenger speakers. Has new speakers, both unused and have not been broken in)
1X Radiator (Replaced 100 miles use. no clogs, see thru fins)
1X Parking Brake Mechanical Assy.
1X Steering Column (Cruise Control Opt.)
1X Gauge Cluster (gauges have fallen inside, may need to be re adjusted All were working on park) Ext. Battery and oil INCL. (Working on park)
1X Decklid (Minus latch mechanisms - Sold) Front Hood (Has some nicks and chipping. Needs repaint)
1X Fan shroud (New Motor 100 miles)
4X Spare 14" Stock Rim sets (Bad Tires, Selling for rims)
1X Complete HVAC box (No AC parts or Heater Core incl.)
1X A/C Controls
2X Fender (Right Replaced New)
1X Shifter ASSY. 4 Speed
1X Fuel Tank (Protection coated, needs patch near front strap)
1X Front/Rear Bumpers (Front Brand New Verified 50 Miles
1X Tinted Sunroof Glass (Good Hardware, Glass Replaced)
2X Shift Cables (Select stock, Shift Rodney Dickman Replacement 100 miles)
1X 86 ECM (working on park)
1X Wiper motor/ Arm Set (working on park)
1X Washer Fluid Reservoir + Motor Pump (working on park)
1X Battery Tray Plastic Parts (Condition varies)
1X Misc Shielding sets (engine/engine bay/etc.)
1X Radio AM/FM GM Stock Cassette EQ Reman w/ Aux Mod (Working Verified. Completely rebuilt/serviced)
2X Rear Decklid Vents
IN CAR/ TO BE DECIDED
1X Rear Body Clip/ Quarter Panels (Driver has rock damage/missing trim)
1X Full Engine/Harness V6 2.8L (Upgraded Distributor, 38,709.8 Miles on park. Ran Excellent, may need inspection due to sitting)
1X Front Suspension (Stock Shocks, still good. Surface Rust)
1X Rear Suspension (Stock Shocks, still good, surface rust/minor pitting?)
1X Radio antenna wiring (Lost antenna)
1X Brake Master/ Prop Valve (Working when last moved last month)
1X Rodney Dickman Clutch Master/Slave (Aprox 20 miles, New)
1X Clutch Line (New 100 Miles)
1X Fuel Tank (Patched, Bottom rust leak New Pump and Sending Units Has gas!!)
2X Fuel Line Set (Feed Send)
1X Fuel tank tubing (New 100 Miles)
Phone number (Feel free to ask any questions here on text. I can also send the pictures here as well): (616) 888-9728
PICTURES (MORE ON REQUEST)
[IMG]https://images.fiero.nl/userimages/Robodog_X920/20220 610_114504.jpg[/IMG]
Riley G. 1987 Pontiac Fiero Base, 1988 5 speed, and 1986 SE 4 speed V6 owner.
[This message has been edited by Robodog_X920 (edited 06-15-2022).]
Total ratings: 461
Report this Post06-12-2022 01:01 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry. Gotta ask. Why part out a 38K, (apparently) not crashed, (apparently) not rusted car?
Good luck with sale. I'm still looking...
Robodog_X920
Report this Post06-13-2022 11:14 AM Click Here to See the Profile for Robodog_X920Send a Private Message to Robodog_X920Edit/Delete MessageReply w/QuoteDirect Link to This Post
Tried selling as a whole with no luck. But I am in severe debt and this is food money, and get the government off me money, and cancer treatment money. If it was a perfect world, where I wasn't struggling to stay alive, wouldn't have gone this route.
88FormulaDuke
Report this Post06-13-2022 09:23 PM Click Here to See the Profile for 88FormulaDukeSend a Private Message to 88FormulaDukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh man, sorry to hear about your situation.
I’m looking for the black sail panel inserts just behind the door windows.
Also need a glove box door from between the seats.
Could also use the trim from around the radio/climate control/vents, and around the gauges.
Thanks!
copperhens
Report this Post06-14-2022 10:34 AM Click Here to See the Profile for copperhensSend a Private Message to copperhensEdit/Delete MessageReply w/QuoteDirect Link to This Post
You said you have a full e brake cable? I’d be interested.
Robodog_X920
Report this Post06-14-2022 11:46 AM Click Here to See the Profile for Robodog_X920Send a Private Message to Robodog_X920Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep! Still in the packaging. Should include all the cables and new hardware as well. I can get you some pictures if you would like, and a quote on that
copperhens
Report this Post06-18-2022 06:27 PM Click Here to See the Profile for copperhensSend a Private Message to copperhensEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you email me at copperhens@icloud.com? I don’t check here all the time.
Fitz301
Report this Post07-06-2022 11:07 PM Click Here to See the Profile for Fitz301Send a Private Message to Fitz301Edit/Delete MessageReply w/QuoteDirect Link to This Post
How much for the chassis, doors and seats?
THX
[This message has been edited by Fitz301 (edited 07-06-2022).]
PhatMax
Report this Post07-07-2022 07:37 AM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
How much for the vacuum line set ?
Robodog_X920
Report this Post07-08-2022 07:32 AM Click Here to See the Profile for Robodog_X920Send a Private Message to Robodog_X920Edit/Delete MessageReply w/QuoteDirect Link to This Post
THX
Chassis is not being sold, doors have been sold, but the seats i would say $200-300 each. I can message you some more pictures if you would like, but they are in amazing condition minus the passenger being dirty from the headliner removal.
Robodog_X920
Report this Post07-08-2022 07:35 AM Click Here to See the Profile for Robodog_X920Send a Private Message to Robodog_X920Edit/Delete MessageReply w/QuoteDirect Link to This Post
Robodog_X920
Member since Jan 2019
Can do $100 pickup or $80 shipped + shipping
30+mpg
Total ratings: 97
Report this Post11-10-2022 08:14 AM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
wiper arms?
wannav8
Report this Post11-10-2022 06:22 PM Click Here to See the Profile for wannav8Send a Private Message to wannav8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 30+mpg:
wiper arms?
If he cant help you let me know, I will pm you.
FIER086
Report this Post11-12-2022 03:23 PM Click Here to See the Profile for FIER086Send a Private Message to FIER086Edit/Delete MessageReply w/QuoteDirect Link to This Post
How much for the hood. I live just south of GRand Rapids.
Thanks
Tyler
Robodog_X920
Report this Post12-06-2022 04:23 AM Click Here to See the Profile for Robodog_X920Send a Private Message to Robodog_X920Edit/Delete MessageReply w/QuoteDirect Link to This Post
wiper arms?
$20 for the set and the wiper blades if I still have them sound good? They were brand new and not used more than once so I will double-check for dry rot on those
Robodog_X920
Report this Post12-06-2022 04:25 AM Click Here to See the Profile for Robodog_X920Send a Private Message to Robodog_X920Edit/Delete MessageReply w/QuoteDirect Link to This Post
Robodog_X920
Thanks
Tyler
I can do $100 on that, I will double-check the condition its been outside in a couple of storms and buried in snow as well before hand.
