Lots and lots of Fiero parts for sale.... by olejoedad
Started on : 03-09-2022 07:00 PM
Replies : 55 (1482 views)
Last post by : 88FormulaDuke on 05-17-2022 12:25 AM
Mar 9th, 2022
olejoedad Member Posts: 18114 From: Clarendon Twp., MI Registered: May 2004
As the title says, lots of stuff for sale. Let me know what you need, it's time to clean out the storage areas! If you need it, probably have it.
07:00 PM
KB2 Member Posts: 59 From: Lakeland, TN Registered: May 2002
PM sent. Thanks, Kevin
07:29 PM
Spoon Member Posts: 3762 From: Sadsburyville, PA. 19369 / USA Registered: May 2004
MY8
Spoon
08:02 PM
Mar 10th, 2022
Rare87GT Member Posts: 5046 From: Wichita, KS USA Registered: Oct 2001
Do you happen to have a dot matrix 5spd bezel?
Thanks,
Amir
------------------ 88 Formula - 3800SC/4t65eHD 88 Coupe - 3800SC/4t65eHD 87GT - Great Blue Chop Top
12:43 AM
Rsvl-Rider Member Posts: 1219 From: Sacramento, CA Registered: Feb 2014
I'm looking for a seat back cover like this for my 87 GT. I need it for the driver side but I have heard they are interchangeable. Shipping to 95610.
01:28 AM
Stingray92 Member Posts: 101 From: Indiana Registered: Feb 2014
I need a washer fluid nozzle, aero rocker's long driver & passenger, lower door side moldings. Thanks, Chuck
06:09 PM
str8maxn Member Posts: 278 From: Fontana CA Registered: Aug 2018
Parking brake assembly ?
06:44 PM
Mar 11th, 2022
m0sh_man Member Posts: 8460 From: south charleston WV 25309 Registered: Feb 2002
also looking for a 1988 dot matrix 5 speed shift bezel/plate matthew
11:44 AM
css9450 Member Posts: 5426 From: Glen Ellyn, Illinois, USA Registered: Nov 2002
How about a 1988 dot-matrix Automatic-transmission bezel plate? I need one that is pretty much like-new to replace mine that has some scratches.
02:33 PM
Mar 12th, 2022
Curtisk1060 Member Posts: 298 From: Colorado Springs, Colorado, USA Registered: Dec 2011
Looking for a right front "Bridge" for my 87 GT, this is the part that holds the caliper to the spindle, if you had that part including a good condition caliper I would consider that as well for a fair price, let me know.. Curtis
09:15 PM
Mar 13th, 2022
FormulaGT Member Posts: 780 From: Santa Barbara, CA USA Registered: Sep 2003
P.M sent
09:36 AM
Mar 16th, 2022
MulletproofMonk Member Posts: 3079 From: Dayton, OH (Bellbrook, OH 45305) Registered: Oct 2005
Raydar Member Posts: 40730 From: Carrollton GA. Out in the... country. Registered: Oct 1999
Joe,
One of the guys in our group needs a right rear knuckle for an 88. Might you have one?
[This message has been edited by Raydar (edited 03-16-2022).]
02:38 PM
No sir, I do not. What is the matter with his knuckle?
04:19 PM
quote Originally posted by MulletproofMonk: do you have an 87 passenger side coolant tube with the heater return in it? I think the 87 was the only year that had it other then the 88. Trying to retro fit this into my girlfriends 86 with an 88 v6 so i don't have to use that bypass.
No sir, I do not.
I would pull the plug on the water pump, put the nipple in and run the hose along the lower frame rail, as per OEM for the 86. The 87 coolant tube is a one off, very hard to find.
[This message has been edited by olejoedad (edited 03-16-2022).]
04:26 PM
quote Originally posted by olejoedad: No sir, I do not. What is the matter with his knuckle?
I think he had a caliper bolt to come loose. Bad things happened, including a trashed knuckle.
I'm not sure if it's broken or just bent. Either way...
08:41 PM
Mar 17th, 2022
Yeah, that a bad day, but it could have been worse....
07:36 AM
EMMnM Junior Member Posts: 4 From: Layton, Utah Registered: Mar 2022
Do you have intake manifold and valve covers for the 2.8 engine
10:34 AM
PM sent
11:01 AM
quote Originally posted by EMMnM: Do you have intake manifold and valve covers for the 2.8 engine
Lower, middle, upper or all three?
01:47 PM
quote Originally posted by olejoedad: Lower, middle, upper or all three?
I think I need just the upper for the intake and did you have some valve covers for it too?
10:05 PM
Mar 19th, 2022
quote Originally posted by EMMnM: I think I need just the upper for the intake and did you have some valve covers for it too?
I have upper intake and valve covers.
What year is your car?
02:13 PM
quote Originally posted by Curtisk1060: Looking for a right front "Bridge" for my 87 GT, this is the part that holds the caliper to the spindle, if you had that part including a good condition caliper I would consider that as well for a fair price, let me know.. Curtis
I have the caliper mounting bracket, but only sold in pairs.
02:15 PM
PM sent, Thanks, Kevin
04:03 PM
quote Originally posted by olejoedad: I have upper intake and valve covers. What year is your car?
It’s an 84 but I’m putting a 3.1 Camaro engine in it (its almost the same engine)
06:15 PM
Mar 21st, 2022
Is the engine a cast iron block and heads?
[This message has been edited by olejoedad (edited 03-21-2022).]
09:31 AM
rkirkpatrick Member Posts: 136 From: Royalton, Ill, USA Registered: Jul 2015
Left Rear quarter panel... 86 Notchback....Gold if I am lucky..
01:16 PM
Brian D Member Posts: 25 From: York, PA Registered: Sep 2021
I just need two of the torx screws that attach the side marker lights to the body. I'll take a few more if you have them.
08:10 PM
quote Originally posted by olejoedad: Is the engine a cast iron block and heads?
It should be
10:38 PM
Mar 22nd, 2022
Cajun Member Posts: 1555 From: Youngsville, La., USA Registered: Dec 2003
Looking for a Instrument cluster surround in dark gray. PM sent......... Thanks
09:01 AM
Mar 29th, 2022
sunkship Junior Member Posts: 1 From: arkansas Registered: Mar 2022
Looking for factory rear spoiler stands, plain right side outer door skin, and front bumper cover.
------------------ Carl Nelson
12:24 AM
Apr 5th, 2022
XxdjxX89 Member Posts: 123 From: Las Vegas Registered: Feb 2015
Do you have m17 transmission?
12:52 AM
Apr 12th, 2022
8t6gt Member Posts: 13 From: Denver, CO Registered: Mar 2022
quote Originally posted by olejoedad: As the title says, lots of stuff for sale. Let me know what you need, it's time to clean out the storage areas! If you need it, probably have it.
12:23 PM
I'm looking for a clutch release arm for 85 or 86 GT with Muncie 4-speed! Any chance you have one of those?
12:24 PM
Only on good transmissions. Sorry, but I can not separate.
03:19 PM
marc-alan Member Posts: 373 From: pottstown, pa usa Registered: Mar 2010
Do you have the spring that is under the front hood? I believe it's conical in shape
09:24 PM
Lilchief Member Posts: 1733 From: Vevay,Indiana Registered: Feb 2004
Looking for an 88 2.5 serpentine w/p pulley or the whole thing. Thanks Rick
10:36 PM
Apr 14th, 2022
kevin Member Posts: 2722 From: Elk Grove, CA USA Registered: Jan 2000
I need to purchase the door glass mirror adjuster. This is the electrical piece on the center councel. It is the switch,in between the driver/passenger seat glass ( on the center council) that electrically adjusts both door mirrors. Does my description make sense? Please let me know. Cordially, Kevin Sullivan
09:02 PM
Apr 17th, 2022
NightMare Cruiser Member Posts: 2035 From: Edison, NJ USA Registered: Aug 2009
Windshield??
08:48 PM
Windshield??
09:01 PM
