Looking for an 88 clutch master cylinder, and a glove box door from between the seats. I could also use the 88 “dot matrix” 5-speed shifter plate and boot. I also need the rear sway bar brackets that mount to the rear strut. Thanks!
need lower radiator support 84 85 86 4 cyliner, right rear side marker light, gray gauge cluster surrounf. priece with shipping to allentow pa war51@rcn.com thanks wayne
I am looking for 84-86 headlight, headlight motor and radiator fan wire harnesses. I also need rebuildable headlight motor cores and V6 throttle body cores. Also t-stat housings in refurfishable condition.
I’d like to convert my car to remote trunk release. Do you have the switch (switches?) with the trim on the right side of the gauge pod, and the remote trunk release mechanism from under the deck lid?
I also need the 88 rear sway bar mounting brackets that attach to the strut.
Also, do you have the power window switches and trim plate assembly?
[This message has been edited by 88FormulaDuke (edited 05-17-2022).]
