  The Mall
  F23/F40 bracket mounts
F23/F40 bracket mounts by thelinsells
Started on: 10-10-2021 03:23 PM
Replies: 10 (437 views)
Last post by: thelinsells on 10-24-2021 01:19 AM
thelinsells
Report this Post10-10-2021 03:23 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
F23 and F40 transaxle mounting brackets.To mount most of these trans to Fiero subframes (cradles).Useing standard OEM type Fiero rubber mounts.No mods needed.
Total ratings: 463
Report this Post10-10-2021 03:30 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I messaged you a while back. I need brackets for the GM V6 Metric F23. (This is the trans pattern that bolts to the stock V6 and the 3800.)
Do you still need pics of my trans?
thelinsells
Report this Post10-10-2021 10:17 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes there are several different castings of this tranaxle .I also have the shift correction kit and clutch adapter.These last two items are universal.
copperhens
Report this Post10-12-2021 07:52 AM Click Here to See the Profile for copperhensSend a Private Message to copperhensEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you email me? copperhens@icloud.com
thelinsells
Report this Post10-12-2021 07:57 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I can ; thelinsells@cox.net
cam-a-lot
Total ratings: 97
Report this Post10-14-2021 08:58 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you develop mounts that work with the 60 deg F23 bellhousing that bolts to 2.8/3.4/3800 engines, it would be a great addition. If I remember correctly, your mounts are for the ecotec engine /,matching transmission combo. So it is good to specify "which" F23 the parts are compatible with
Thanks
thelinsells
Report this Post10-14-2021 11:03 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wont know until I see the trans
cam-a-lot
Total ratings: 97
Report this Post10-22-2021 06:30 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am sure the F23 is readily available at a junkyard near you. Look for 2000-2002 Cavalier (non ecotec) motor. 2200 engine, VIn 4
There are many near you. This is the trans swap kit that I , and others , have asked you to look into developing for Fieros that want to use an F23, but not the Ecotec bellhousing.
https://www.fiero.nl/forum/Forum1/HTML/087296.html
[This message has been edited by cam-a-lot (edited 10-22-2021).]
thelinsells
Report this Post10-22-2021 07:45 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes; have L.K.Q. send the transaxle you want brackets for to my shop, and I will make brackets to fit it to any Fiero.
cam-a-lot
Total ratings: 97
Report this Post10-23-2021 06:39 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Roger
I am not sure it makes sense for someone to ship you a transaxle just for this. Since they are only $200, and in the Fiero world , the demand is clearly toward the 60 deg V6 configuration, it may make sense for you to grab a local transmission yourself and just make the brackets. I am sure they will sell, as there are far more 2.8/3.4/3800 Fieros out there than ever will be with Ecotec motors.
Why not just go to a local junkyard and grab one? Mileage doesn't even matter, since you only need the case. Up to you, but this is what I would suggest. I can't imagine someone buying and shipping you a transmission just for this,
Good luck!
[This message has been edited by cam-a-lot (edited 10-23-2021).]
thelinsells
Report this Post10-24-2021 01:19 AM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have brackets for F40.Also I have shift correct kit ,and motor bracket and clutch adapter.
