  The Mall
  3800 Speed Parts ALL New
3800 Speed Parts ALL New by streetstockSS83
Started on: 08-31-2021 04:01 PM
Replies: 5 (411 views)
Last post by: streetstockSS83 on 09-03-2021 11:17 AM
streetstockSS83
Report this Post08-31-2021 04:01 PM Click Here to See the Profile for streetstockSS83Send a Private Message to streetstockSS83Edit/Delete MessageReply w/QuoteDirect Link to This Post
SOLD 09/03/2021
Build some power in your 3800 SWAP? here is a Great Start. Looking to Sell it all together.
Make offer on everything.
The Roller rockers are Rare and over 300.00 now if you can find them.
Leave me a Message and I will get back to you.
1. Pair of Mag/Pressure tested, Ported & cut for big valves set of heads. Comes w/1.900 Int. 1.57exh Manley valves.
2. Comp-Cams Manley Custom Steel Valve Springs Locks & Retainers.
3. INTENSE Push-Rods
3/8 x .083 (.040 oil Res.) 7.4 inch.
4. Roller Lifters 875-12.
5. Roller Rockers w/hardware
YELLA TERRA ROCKERS HOLDEN
ULTRA-LITE 5/16" 1.7 (Rare YT6649).
6. ARP Head studs 193-4001.
7. ARP Rod Bolts 123-6002.
8. Oil Pan windage tray style Gasket.
9. Dbl Roller Timing Chain (CS6150).
10. Custom Ground & Polished Crank.
Matching Clevite Rod and Main bearings Coated 10/20.
11. Cometic MLS Head gaskets.
12. Supercharger Manifold and Inter-cooler (Base Only).
13. Hard to find Thermostat Housing.
14. Misc stainless Bolts and gaskets.
15. HP tuners with older laptop (I Dont know about this software, It just goes with the total package.)
I will box up and ship. No reasonable offer ignored seven O six sixSixNine seven 5 O 9
[img]https://images.fiero.nl/userimages/streetstockSS83/upperShelf.jpg[/img ]
[This message has been edited by streetstockSS83 (edited 09-03-2021).]
streetstockSS83
Report this Post08-31-2021 04:08 PM Click Here to See the Profile for streetstockSS83Send a Private Message to streetstockSS83Edit/Delete MessageReply w/QuoteDirect Link to This Post
Added This was from a Shop that closed sometime ago and I purchased everything I could for my project that is now Sold.
Larry Hubbert
Report this Post08-31-2021 04:16 PM Click Here to See the Profile for Larry HubbertSend a Private Message to Larry HubbertEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have any idea or even a ball park idea as to how much you are looking to get for everything you have listed here. We sure could use an idea as to what price range your are in, so we do not insult you with our offers. Thank you.
streetstockSS83
Report this Post08-31-2021 04:48 PM Click Here to See the Profile for streetstockSS83Send a Private Message to streetstockSS83Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am trying to set a few things right so 25% of the total value + or -
My number is still the same of 706 669 7509 with all I have went through I will not be
insulted so Please make an offer, you may send to my cell if you wish.
qwikgta
Total ratings: 84
Report this Post09-02-2021 11:39 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
streetstockSS83
Report this Post09-03-2021 11:17 AM Click Here to See the Profile for streetstockSS83Send a Private Message to streetstockSS83Edit/Delete MessageReply w/QuoteDirect Link to This Post
SOLD 09/03/2021
