Update System
  The Mall
  1988 Fiero Formula $2500.00
1988 Fiero Formula $2500.00 by ChuckLS1
Started on: 04-17-2021 06:41 PM
Replies: 9 (1364 views)
Last post by: kevin on 09-23-2021 08:40 PM
ChuckLS1
Report this Post04-17-2021 06:41 PM Click Here to See the Profile for ChuckLS1Send a Private Message to ChuckLS1Edit/Delete MessageReply w/QuoteDirect Link to This Post
For sale is my 1988 Fiero Formula with a fastback conversion. It has 148374 miles on it. It is stock. I have had the radiator and water pump replaced a few years ago. The fuel tank was just cleaned and repainted. Fuel pump and filter was replaced. The car does need some work.
The car does idle but has no power when you step on the gas. I believe the throttle position sensor has gone bad. The threads holding it into the throttle body are stripped so it does not stay in there very well. The drivers side tail light has a hole in it, I have a replacement which will go with the car. The drivers side sail panel is not on, I do have it. Drivers drip rail broke off, I still have it and it will go with the car. Needs a new windshield. The passenger side trunk corner has some rust, the drivers side is good. Any questions, please ask. Car is in Greensboro, NC [img]http://images.fieroforum. com/userimages/ChuckLS1/pass%20corner%20rear.JPG[/img][img]http://images
.fieroforum.com/userimages/ChuckLS1/int%205.JPG[/img]
[img]https://images.fiero.nl/userimages/ChuckLS1/int%209 .JPG[/img]
[img]https://images.fiero.nl/userimages /ChuckLS1/front.JPG[/img]
https://www.youtube.com/watch?v=Q0QVg9X6SX8
[This message has been edited by ChuckLS1 (edited 05-15-2021).]
reinhart
Report this Post04-18-2021 03:07 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are those the original spark plug wires?
ChuckLS1
Report this Post04-18-2021 09:42 AM Click Here to See the Profile for ChuckLS1Send a Private Message to ChuckLS1Edit/Delete MessageReply w/QuoteDirect Link to This Post
They were on the car when I bought it in 2008, not sure how old they are.
Chuck
88 Formula W/fastback
2000 Grand Prix GTP
Report this Post04-25-2021 10:14 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The price may be a bit optimistic for parts car.
Total ratings: 202
Report this Post04-26-2021 10:06 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Optimism is good!
Gotta start the bidding somewhere!
ChuckLS1
Report this Post05-15-2021 11:15 AM Click Here to See the Profile for ChuckLS1Send a Private Message to ChuckLS1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Price now $2200.00
countach711
Report this Post05-18-2021 02:34 AM Click Here to See the Profile for countach711Click Here to visit countach711's HomePageSend a Private Message to countach711Edit/Delete MessageReply w/QuoteDirect Link to This Post
check your vacuum lines and make sure they are all still attached and good. There is one on the under side of the mapp sensor which is hidden from view that goes directly into the manifold. If it's not attached you will have no power.
ChuckLS1
Report this Post06-02-2021 07:36 PM Click Here to See the Profile for ChuckLS1Send a Private Message to ChuckLS1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the tip, I’ll give it a try!
ChuckLS1
Report this Post09-13-2021 07:09 PM Click Here to See the Profile for ChuckLS1Send a Private Message to ChuckLS1Edit/Delete MessageReply w/QuoteDirect Link to This Post
SOLD
Chuck
86 Fiero GT 3800SC
2000 Grand Prix GTP
kevin
Report this Post09-23-2021 08:40 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
