As Nelson mentioned above, if you want a 355 interior, Amida is the way to go but make sure to have a huge bank account.
I do not know about a huge bank account but the delivered cost will certainly be based on the bare parts plus the type of upholstery material desired. Obviously leather will cost more than vinyl. That being said, I would use no other F355 interior manufacturer than Amida. I also like his G1 interior but am not familiar with the cost on that one.
Nelson
[This message has been edited by hnthomps (edited 09-09-2020).]
Looks amazing. I also am trying to find out the truth about the Gate shifter. Does it work ok when you change it out to the narrow one from the fiero store? I thinking on sending mine back (OEM) because some say it will hurt the cables etc and some say its fine.
If I cant afford or do his, I will do OEM and modify or do my own. I have all the tunnel switches etc to put in.
How can I get in contact for pricing to this fellow?
D
You can PM him on this forum under the name AMIDA. If that does not get a response, PM me and I will give you his other contact info that I have on file. I cannot help you on the shifter question and just used Amida's shifter which came assembled with the center console.
Question 1 Do the vents and other things for the dash come with it? Door handles, etc
2 Explain more about the wire harnesses... how they work or what they do to be needed. I have been thinking about the digital ones for Fiero offered.
3 What is the turn around time for the kit??
1. When I purchased my interior I was offered a choice of vents ( including real Ferrari vents for an additional charge) so I can say that the upholstered interior comes with vents. I believe that the door handles were also preinstalled on the door panel but cannot specifically remember since it has been so long ago.
2. The wiring harness is intended to simplify the wiring of the VDO instrumentation to the Fiero wires. It is strictly a time saver and you need to evaluate the cost versus your time.
3. Turn around is likely to vary with what Amida has in the current production mode. Thus, this is best discussed directly with him.
