  The Mall
  ebay- FIero carpet question
ebay- FIero carpet question by cam-a-lot
Started on: 10-16-2019 10:24 AM
Replies: 9 (344 views)
Last post by: cam-a-lot on 10-17-2019 04:16 PM
cam-a-lot
Total ratings: 97
Report this Post10-16-2019 10:24 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone bought the carpets for sale on eBay that supposedly fit the Fiero?
My 88 Beechwood carpet is showing a bit of wear on the driver's side and I am looking for a very clean replacement. Used is very hard to find unless it is also work or dirty
Has anyone bought the ones on eBay / Pictures or review to share about fit, color, etc?
Mike in Sydney
Report this Post10-16-2019 09:22 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did. My advice: Save your money. The fit was bad. The material was disappointing. I went back to the original carpets after taking them getting them out of the car ans having them professionally cleaned but YRMBD (your results may be different).
If you're planning on keeping the car and the carpet is really bad, I suggest you bite the bullet and take it to an upholstery shop and get custom carpets made. If the wear in the carpet is due to heel damage, etc., you can think about having an upholstery shop to sew in a rubber or carpet mat over the damaged area.
Mike in Sydney
Spadesluck
Report this Post10-17-2019 01:21 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got carpet from the Fiero Store. The carpet is not the best of quality but it does work. There is plenty of material and it will need to be trimmed down to fit properly.
32Ford
Report this Post10-17-2019 07:41 AM Click Here to See the Profile for 32FordSend a Private Message to 32FordEdit/Delete MessageReply w/QuoteDirect Link to This Post
MR Mike, no one elses are better!
da.slyboy
Report this Post10-17-2019 10:49 AM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting, has Mike always made Fiero carpets?
N0ctrnl
Report this Post10-17-2019 11:19 AM Click Here to See the Profile for N0ctrnlSend a Private Message to N0ctrnlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shho13
Report this Post10-17-2019 03:23 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought one of those carpets off Ebay, the fit and finish is decent at best, even with the extra material that needs to be trimmed off.
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
Report this Post10-17-2019 03:50 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The mats that I purchased on eBay made by Lloyds Mats were really well made and absolutely beautiful . The so called "molded" carpet that I purchased from Trim and Things required a lot of fitting. It took a ton of work, extra jute and much cutting to make it fit. Mr Mike recommends placing the new carpet over the old and that is what I will do next time. The old carpet has the shape and the new will just follow it. To replace the carpet the seats, back side pillar trim, back panel, bottom door panels, shift and center console need to be removed. Figure about a days worth of work.
Report this Post10-17-2019 03:52 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2000
[This message has been edited by Dennis LaGrua (edited 10-17-2019).]
cam-a-lot
Total ratings: 97
Report this Post10-17-2019 04:16 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks everyone for the feedback
