  The Mall
  Brake and Clutch pedals for Auto-Manual Conversion
Brake and Clutch pedals for Auto-Manual Conversion by Dennis LaGrua
Started on: 07-18-2019 03:25 PM
Replies: 1 (165 views)
Last post by: GSingh94 on 08-06-2019 03:15 PM
Report this Post07-18-2019 03:25 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you are doing the auto to stick conversion you will need to add a new clutch and brake pedal. Here is a set of brake and clutch pedals used on manual Fieros. They are both in very good condition and the brake pedal is the all steel unit that won't bend like same of the factory aluminum pedals. Included is the clutch bracket that will bolt to the brake bracket and supply the mounting studs for the clutch master cylinder. The return spring and one bushing are also included but a few small parts may be needed to complete this end of the swap.
$45 + $13.95 shipping paypal accepted
GSingh94
Report this Post08-06-2019 03:15 PM Click Here to See the Profile for GSingh94Send a Private Message to GSingh94Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM Sent
