I have designed and machined high strength aluminum front hubs for 84-87 cars. 7075 aluminum. They weigh roughly 3 lbs depending on the application. That's about 4lbs lighter than a modified cast iron hub, you will loose 8lbs of unsprung weight. They come powder coated black with the races and studs already pressed in. You also get new bearings, you provide the grease. These are for off road use only! Not responsible if you use them on the street, use at own risk.
I have hubs for Grand Am/Berreta swap on hand and I can also custom machine a set to your specs, offset, bolt pattern, rotor centering ring, ect..
$350shipped for the Grand Am/ Berreta hubs $400 custom machined to your specs
[This message has been edited by sluppy123 (edited 04-07-2016).]
Wow, that is super. Way beyond what I have to spend on the Fiero right now, but going at the top of the list to get. A pair of hubs with a Corvette-sized center bore would be excellent.
I currently have 2 pairs of hubs machined for C4 and C5/C6 corvette rotors, w/ fiero 5x100mm bolt pattern. $400 for a pair
I also have one pair machined for a 13" Enclave rotor, w/ fiero 5x100mm bolt pattern, caliper adapter brackets to mount 88 calipers on 84-87 cars. $635
I have a set of these available. They are machined for either a 12" C4 or 13" C5 Corvette rotor. $400 shipped in the us. if outside the US you pay actual shipping costs.
I need 87 fiero 5x120
