  The Mall
  WTB: 88 oil pressure sender connector
WTB: 88 oil pressure sender connector by Matthew_Fiero
Started on: 07-04-2015 07:14 PM
Replies: 5 (151 views)
Last post by: fierofool on 07-07-2015 01:40 PM
Matthew_Fiero
Total ratings: 51
Report this Post07-04-2015 07:14 PM Click Here to See the Profile for Matthew_FieroSend a Private Message to Matthew_FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi.
I have a 3800 swap but the Fierostore connector I soldered in is loose at the connectors! No matter how much connecting grease or zip ties I apply I can only make the connection temporary.
Does anyone have a connector they can cut off their harness and send to me?
Thank you,
Matthew
Report this Post07-05-2015 12:11 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Available at auto parts stores, or your nearest wrecking yard.
They were used on many GM cars of the era.
Three or four wire will work, as long as the plug is the 'notched oval' style.
The two outer wires are the fuel pump circuit, the center is the gage.
If you find a four pin, don't use the wire by the notch, just cut it off.
[This message has been edited by olejoedad (edited 07-05-2015).]
Curtisk1060
Report this Post07-06-2015 11:16 AM Click Here to See the Profile for Curtisk1060Send a Private Message to Curtisk1060Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got mine on Rock auto, just search for a 1988 Fiero or similar vehicle ..Curtis
[This message has been edited by Curtisk1060 (edited 07-06-2015).]
Shho13
Report this Post07-06-2015 11:47 AM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
General Motors PN: 12085499
http://m.ebay.com/itm/281367515992?nav=SEARCH
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
canfirst
Report this Post07-06-2015 11:59 AM Click Here to See the Profile for canfirstSend a Private Message to canfirstEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check with Rodney Dickman, see following link: http://rodneydickman.com/ca...h=21&products_id=282
Report this Post07-07-2015 01:40 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rock Auto and most of the franchise auto parts stores also sells the connector if you haven't gotten one, yet.
