  The Mall
  Updated parts list. cut up and scrapped the frame. 86gt and some 84.
Updated parts list. cut up and scrapped the frame. 86gt and some 84. by Scott2scott
Started on: 01-25-2015 01:06 PM
Replies: 2 (362 views)
Last post by: rbell2915 on 01-25-2015 08:13 PM
Scott2scott
Report this Post01-25-2015 01:06 PM Click Here to See the Profile for Scott2scottSend a Private Message to Scott2scottEdit/Delete MessageReply w/QuoteDirect Link to This Post
heres an updated parts list . parted out my 86gt. have parts off and in garage. cars space frame was cut up and scrapped on last Thursday. time me get rid of all parts. open to any reasonable offers. I would like to get back to my 3800sc project again. parts need to leave. lol ...Inner sail panle black trim both sides, fiero spare tire hold down with fiero logo knob, air box, gas tank door assembly, a/c control, spare tire, a/c blower motor, brake booster, gas tank cross member, exhaust heat shield, ecu tray, heater core, whole complete full wireing harness from dash all the to taillights . Front crash plastic, wiper motor, wiper arm, drivers side pilar speaker cover, a/c line from compressor, inside door panels both side with map pockets, trunk carpet, 84 solid engine vent covers , notchback full rear clip, notchback trunk, clutch slave cylinder , clutch starter,ac braket ,motor mount , stock calipars ,fuel rail and injectors, water pump. disrubitor, rocker arms and push rods. crack shaft pully and oil dip stick and tube. lower intake amd middle intake., motor mounts, , fuel sender unit, cat converters, glass, window motors, window power switchs, window regulators. Shocks , side mirrors ,front hood latch and rear deck latch,Steering column,throttle body. exhaust Y pipe and egr tube, map sensor and lines, 6 spark plug heat tubes,thermosat housing with cap,ignition coil cooing duct tube, and two alt. cooling tubes, factory shifter, 4 spd trans,passenger side gt sideskirt,Radio antennta wire and fender mount ,front hood gasket seal,complete brake booster ,Pad rear bumper off 84,Gt dash board, sunroof,Ac compressor bracket , I think I might be leaving some stuff out I will add more as I go look or remember more. the garage floor is full.lol thanks for reading. like I said im open to trade and reasonable offers.
notwohorns
Report this Post01-25-2015 06:46 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
rbell2915
Report this Post01-25-2015 08:13 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
