  The Mall
   2.8 gt fiero throttle body,exhaust Y pipe and egr tube, and more....
2.8 gt fiero throttle body,exhaust Y pipe and egr tube, and more.... by Scott2scott
Started on: 01-09-2015 07:11 PM
Replies: 0 (205 views)
Last post by: Scott2scott on 01-09-2015 07:11 PM
Scott2scott
Report this Post01-09-2015 07:11 PM Click Here to See the Profile for Scott2scottSend a Private Message to Scott2scottEdit/Delete MessageReply w/QuoteDirect Link to This Post
throttle body. exhaust Y pipe and egr tube, map sensor and lines, 6 spark plug heat tubes, evap system, fulling complete wiring from whole car minus headlight harness. this is whole dash and inside wiring throught firewall and engine harness and taillight harness aslo. polished exhaust heat shield to block trunk from heat, thermosat housing with cap, valve covers, lower intake, starter, ac bracket. alternator bracket, vavle cover breather tube, clutch cable , clutch master cylinder, clutch slave cylinder. deck hindges, door hindges. window motors, door glass. door skins. inside door panels. brake calipars,rotors, stock shocks and springs. ecm tray, inside black trims for fastback panels. solid engine vent covers, notchback decklid. notchback rear clip, trunk light housing, ignition coil cooing duct tube, and two alt. cooling tubes, spare tire hold down with atermaket fiero knob, stock air box, gas door and metal trim ring, dash ac control, both seatbelts complete and buckles, spare tire, ac bower fan, heater core, brake booster, rad fan, ac condenser, front and rear crash plastics, wiper motor and one arm, two sun visors but need to be recoverd, drivers pilar spreaker cover, ac line from compressor , trunk carpet, water pump, pullies, hood gasket seal. steerling column. factory shifter, cradle, 4 spd trans, cv axles, upper and lower control arms, knuckles, gas tank, passenger side gt sideskirt, stock gt exhaust with tips. gas tank cross member. all lines and tubes and engine parts . want to sell everything. most is off car now, going to pull motor and trans and cradle . then starting cutting space frame up to scrap it. then back to finishing my 84 fastback 3800sc just need harness and and some odds and ends. to complete. lets me a deal. also open to trades of all kinds, if u don't see what u need just ask. thanks for reading.
