  The Mall
  Considering selling my '84, testing the waters
Considering selling my '84, testing the waters by ike50701
Started on: 11-09-2014 11:09 AM
Replies: 1 (177 views)
Last post by: Lambo nut on 11-09-2014 11:35 AM
ike50701
Report this Post11-09-2014 11:09 AM Click Here to See the Profile for ike50701Send a Private Message to ike50701Edit/Delete MessageReply w/QuoteDirect Link to This Post
It supposedly has 14k miles on clutch and the iron duke. Been in storage for almost 5 years to the day, have had it running recently, (need to put a new battery in it), new starter. I need to get a new drivers side rear brake caliper (seized up), and do brakes all the way around. Tires are in good shape (rears have less than 1k miles on them when parked, minimal weather checking), minimal rust that I can see, clean under the trunk carpet, needs upper quarter panel, prev owner claims blowout, shredded the area above the pass rear wheel well. Also took the lower qtr out, but I have that. Interior needs to be cleaned. Sunroof doesn't leak but could use new gaskets on the hardware in the glass. Headlight isolation relay gave up the ghost, need to figure that out.
If it wasn't for money being tight and that stupid brake being locked up, I'd probably be driving the car.
I dont have any photos of the car right now, but based on the description, what do y'all think its worth?
Lambo nut
Total ratings: 257
Report this Post11-09-2014 11:35 AM Click Here to See the Profile for Lambo nutSend a Private Message to Lambo nutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought mine that sounds just like about the shape of yours when I got it. Had set for a while, needed to replace one caliper, put in a battery, changed the oil, and banged the tank to get the fuel pump to run again. Gave $250 for it.
Kevin
