  Cradle R&R w/o drivetrain drop?
Cradle R&R w/o drivetrain drop? by DaveB1701
Started on: 12-03-2025 04:20 PM
Replies: 9 (132 views)
Last post by: Dennis LaGrua on 12-04-2025 11:03 AM
DaveB1701
Report this Post12-03-2025 04:20 PM Click Here to See the Profile for DaveB1701Send a Private Message to DaveB1701Edit/Delete MessageReply w/QuoteDirect Link to This Post
'87 GT 5-speed. Rotting cradle front bushing mounts, as advised by the shop that replaced my exhaust and clutch. Purchased a relatively clean and solid cradle from a NV salvage yard and will be taking to a shop for media blasting and powder coating during the winter. New poly bushing set, bolts, and the monster washers on order. Q - can a well-equipped shop suspend the engine/tranny, pull the axles, disconnect the struts & brake cables, and replace the cradle, or must the whole pile be yanked?
Been tearing through Forum articles and can't find a definitive solution...
Thanks.
Mike in Sydney
Report this Post12-03-2025 04:30 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Almost anything is possible BUT I wouldn’t do it. Dropping the cradle is not that hard. The instructions and details can be found in the archives.
jelly2m8
Total ratings: 242
Report this Post12-03-2025 04:45 PM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ya you can easily drop the cradle while leaving the drivetrain in place with a proper engine hanging rig, GM actually made a specific one for Fiero's back in the day for the dealerships. It basically spans from one side strut tower to the forward upper frame rail on the other side. Minimal parts removal to place the rig.
I built mine years ago with square tubing and flat plate.
https://www.fierostore.com/.../Default.aspx?Id=300
[This message has been edited by jelly2m8 (edited 12-03-2025).]
Report this Post12-03-2025 04:51 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some owners that have replaced the automatic transmission have done so by firmly holding the powertrain in place with a engine support bar and then removing and replacing the cradle. Point is that it has been done and can be done but with the utmost care. That is how the transmission shops do it. I would only attempt this work if the powertrain is absolutely secured firmly in place with the proper support bar. There are most likely some posts in the archives that show this.
OOPs spoke too soon see above.
[This message has been edited by Dennis LaGrua (edited 12-03-2025).]
Report this Post12-03-2025 05:15 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is my preferred method for transmission work. I built mine for the LS4/F40 application. The side plates lock into existing holes in the top of the strut tower, rests on the top of the frame rails, then when the bar is bolted in place, everything is locked into position.
cvxjet
Report this Post12-03-2025 06:24 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have changed transmissions and clutches , and also swapped out cradle using an engine support...they can be unstable, if used improperly, so I did some mods and added some stuff....Here are some pics and diagrams;
[This message has been edited by cvxjet (edited 12-03-2025).]
cartercarbaficionado
Report this Post12-03-2025 07:11 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
https://www.harborfreight.c...port-bar-96524.html, they need to make sure they dont crush the brake booster tube or break the dist cap with the chains on this. ive used it when i dropped my 88s cradle to swap my 86 4 speed muncie to a 5 speed getrag and to do some minor repairs to my cooling tubes, i didnt have to disconnect anything but the mounts and brake calipers and struts, i ran a bungie through the caliper and around it a few times before stuffing the hook into a bolt hole for the strut and it worked quite well.
also DO NOT trust them to use that tool correctly. show them it needs to be on the strut towers and the threads need to have rubber caps incase someone tries to close the decklid or attempts to set it on the vents, safer to be anal than having to find parts and spending money when it was fine before
Total ratings: 200
Report this Post12-03-2025 07:23 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't see it mentioned, but I'd also replace the motor mount and transmission mount while it's being done.
You're having a shop do this? Is it just a normal repair shop, or is it something that specializes in older cars? Do you trust them? I only ask because I just don't trust most repair shops.
Vintage-Nut
Report this Post12-04-2025 10:28 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
As mentioned, YES and the Pontiac Fiero Service Manual has the procedure including the fixture...your 'real' question is if 'the shop' is well-equipped.
For Your Information, the procedure is section 2A, Frame (Cradle) and Mounts
Report this Post12-04-2025 11:03 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it is not already obvious, the engine support bar is a different setup for a Fiero than with most FWD vehicles. You can really mess up things doing it as a FWD vehicle. I suggest reading this post thoroughly.
